Headers and Stock Exhaust?
I do not want to spend $1500 on a cat back that provides little to no performance gain. In the end all I care about is performance. A sound change would be nice but not necessary and I know headers are a definate performance gain. I also like the stock look of the exhaust tips. I was just curious about the sound.
I have hijacked my own thread, I know. I still would like more opinions on my first post though.
Greentank, If you have a sound bite that would be great!
In my opinion, the headers and OEM mufflers at idle and cruising speed are so much like stock (and so quiet) that I'm installing a Corsa Sport system this weekend.
By the way, in an A4 which would be far worse than a manual trans there is also no drone or objectionable resonance. I'm pretty sensitive to the drone I have in my ZR1 and won't tolerate it in my C6. If you want quiet but also want to wake the car up, do the headers and airbox with a dyno tune and stock mufflers. If you want a bit more of a performance car sound, I'll let you know how the Corsas are no later than next weekend.
LGMs, KOOKS, ARH, Stainless Works, and Dynatechs are made from 304 stainless steel. Headers are like most anything else, you get what you pay for, and there is lots of information here and in the C5 section about the performance of LGs, KOOKS, ARHs, Dynatechs, etc.
304 stainless is extremely corrosion resistant, much more so than mild steel. 304 Stainless also dissipates heat much better than mild steel, hence no reason to coat it other than looks.
A lot of times exhaust components corrode from the inside out due to moisture, sometimes acidic moisture, which settles inside the pipes when the car is not running.
The coating will typically guard against this, but in areas where the integrity of the coating has been breeched or is thin,, inside the flanges, and collectors, etc, rust can and will start in mild steel exhaust components and continue causing the coating to blister, much in the same way as the finish on a car blisters when surface rust takes hold.
Eventually it can rust through.
http://forums.corvetteforum.com/showthread.php?t=919807
http://forums.corvetteforum.com/show...post1545319356
http://forums.corvetteforum.com/show...p?p=1551290513 post #10
http://www.instant-g.com/Products/Ex...t/DSCN7010.JPG
http://images.google.com/imgres?imgu...%3Den%26sa%3DN
http://z06vette.com/forums/showthread.php?t=17387
My advice, if I were I going to drop the dough on headers, I would strongly consider 304 Stainless Steel as opposed to mild steel.
..is ....well you get the picture
and that there is no perceivable difference between "top shelf" and the rest in any of the preceding examples. Experience has taught me different though and I tend not to believe that headers are headers.http://www.digitalcorvettes.com/foru...8&postcount=29
Jet-Hot "Because of its low emissivity and insulating effect, JET-HOT Sterling creates a thermal barrier to protect headers - inside and out - while reducing heat transfer into the engine compartment. But the good news goes beyond protecting headers from thermal fatigue. Plugs, wires, fan motors, water pumps and other heat-sensitive parts get a break, too, in a cooler environment. JET-HOT Sterling will normally boost power when applied to headers for two reasons. First, the coating promotes denser, more potent fuel/air charges by insulating the engine bay from exhaust heat. At the same time, it accelerates the pulsed-vacuum effect on “tuned” headers, resulting in more effective scavenging of cylinders. The increased velocity of exhaust gases produced by higher exit inertia not only clears each cylinder more quickly; it also draws in the next fuel/air charge more efficiently."
No, I hate Scoth.
I went up and corrected it.
And yes you are right, coating is said to offer the benefits that you listed. Less underhood heat, no matter how much less, can only be a good thing.
I may be crazy, but I think the Kooks have a very special sound. I have ridden in an LG car, and it didn't sound like that.
In any case, headers + stock rear is really the way to go for a nice balance of sound.
