roller rockers
Old Feb 7, 2007 | 06:05 PM
mfoti's Avatar
mfoti
[QUOTE=TTRotary;1558850743]Shawn, I am not going to argue with you to prove a point. After very careful consideration, discussion with several vendors, and price comparisons, I chose the roller rocker route. I am very happy with it and I still believe it was the best choice for me. Incidentally, I am making 427RWHP without touching the heads or the cam.
QUOTE]
Is there a link to a post that summarizes your mods?
Old Feb 8, 2007 | 07:50 PM
TTRotary's Avatar
TTRotary
Not sure, but here they are:
Kooks LT headers with cats, stock mufflers, hand ported TB, ported FAST, Vortex Rammer, the rockers, Patriot Dual Gold springs, Manley hardened pushrods, Ti retainers, and of course a tune.
Car did 355 RWHP bone stock, 427 with all the mods and tune, and is back down to 400 after putting on 4.10 gears. The gears were not broken in for the pull, hence the significant power loss. Car goes back to tuner for LT trims in a few weeks, and I expect it to be 10 stronger.
Old Feb 8, 2007 | 07:58 PM
knkali's Avatar
knkali
Not to bust you hump but any graphs to check out of your 425 pull? not that I dont believe you, I just want to see the low end response. Or is there a link you can direct me to. Who did the work? Approx cost of all mods without the 410s?
Old Feb 8, 2007 | 08:02 PM
TTRotary's Avatar
TTRotary
Originally Posted by ShawnDFW
if you're happy with your gains and it has been a trouble free mod, no argument here. 427rwhp without a cam is very nice. if you want to read more of the opposing views, go here
http://forums.corvetteforum.com/show....php?t=1615200
I read it and I see all positive comments except for Bunk22 and his well-documented spring failure and SLP's lack of cooperation. This is not the first instance of this type problem with SLP. Several of the respondents have actual kits on their cars and are very pleased with the results. You can add me to that list.
I think 5 things emerge clearly from all the posts on this topic:
1. Go with a tried and true setup, like the Crane variables, the HS, or the Comps.
2. Avoid the SLP kit.
3. Do not try to cut corners with the ancillary, but critical items: springs, rods, Ti retainers. Same applies to cam swaps. You will spend the money sonner or later anyway.
4. Have an experienced installer do this and set adjustments, and ALWAYS go with a reputable vendor, even if they cost more.
5. There is a lot of misinformation and lack of knowledge on this topic.
FYI, my Comps went in without clearance issues, and they are Shaft Mount rockers.
knkali's Avatar
knkali
BTW what is the stock lift with the stock 1.7s? I want to calc the dif between the 1.8 and the 1.85
Old Feb 8, 2007 | 08:13 PM
knkali's Avatar
knkali
lets see 427-355= 72 hp change. Say 10% fudge factor for dyno on different day = 65hp
say 25 from headers
say 10 from intake and TB
say 25 from RRockers
tune 5hp
sounds logical and without tearing deep into car and probably darn reliable too. (Forget $/hp)
What about torque #s?
Old Feb 8, 2007 | 08:15 PM
TTRotary's Avatar
TTRotary
525 or 522, IIRC.
I took pictures of the dyno charts and can email you a jpeg when I return home. I did not post the pictures because I am fed up with the effort involved to get pictures on the forum, especially my efforts to document the FAST porting which were for naught.
I can tell you that the "after' dyno overlays the stocker exactly, +5HP, until about 3200, and that is where it progressively separates itself from the stock pull. That applies to both torque and HP. I have kept the stock rev limit, for now.
Orange County Corvettes did the work. Big to them. I'd rather not talk about price, but here goes: shaft rockers+springs+ rods+retainers+install: about 1500. Got the Kooks for 1350+500 install. The Vortex was a nightmare because the damn thing doesn't fit. Avoid that intake. FAST I got for $750, and I spent 5 hours porting it, plus OCC spent anoth 3 getting it on. Sean spent 3 hrs on the TB.
And don't ignore the 4.10s. If you can't afford motor mods + gears, then do gears and spend the money on an extra wheelset with Nitto R2 tires to handle the grip. Hands down the single best mod you can do. Gears are $2K installed.
Speed costs money.
Old Feb 8, 2007 | 08:25 PM
TTRotary's Avatar
TTRotary
say 25 from headers
tune 5hp
You can't really break it down like that, because the mods all work together. Change the mods and all the relationships change. For instance, the car was at 400 with mods but before tune. Does that mean if Sean tunes a bone stock car he will add 25 HP? Of course not.
What I can say is that other customers at OCC who did the same mods, but did not port the FAST and used SLP rockers, got 398-403. I think the porting work done on the FAST and the TB made a big difference. One thing is for sure: every little bit helps and it adds up.
Torque was about #5 shy of the HP #. Remember the rev limit was not raised, so additional HP cannot happen without torque gains.
Old Feb 8, 2007 | 08:37 PM
TMyers's Avatar
TMyers
TT thanks for the breakdown. This is just what I am looking for, 400rwhp without breaking into the motor. Now to just find a shop that can do the work. Or I may do it myself. Only thing I may add is a cooler t-stat.
TT by the way did you go with the 1.7 or 1.8?
Old Feb 8, 2007 | 08:49 PM
knkali's Avatar
knkali
no gears here--got an A6 so would expect those kind of #s either but it is all proportional
Old Feb 8, 2007 | 09:13 PM
TTRotary's Avatar
TTRotary
TMyers: mine are 1.85 rollers. 1.7 is stock. Another route is the Crane variable rollers like SpinMonster used, which come off the seat much faster so that they behave almost like a 1.8 initially. This is the same concept as an XER-grind cam where the ramp is steeper.
Knkali - I understand.
Old Feb 8, 2007 | 09:30 PM
layjzay's Avatar
layjzay
Which are better?
Crane 1.8's or Comp 1.85's
Old Feb 8, 2007 | 09:59 PM
  #33
TTRotary's Avatar
TTRotary
Hard to say without graphing the opening curve and comparing the area underneath. I'm going to say the 1.8 Crane variables, if I have to bet. I did the Comps because the installer had experience with them, but had never put the Cranes in a car. Plus the Comps were shaft rockers (paired rocker sets) which is supposedly a more rigid (better) setup.
Old Feb 22, 2007 | 09:51 PM
  #34
mrr23's Avatar
mrr23
St. Jude Donor '15
Thanks Hitman,
So lets say I like the stock cam, then adding some 1.8:1 roller rockers can only make it better throughout the RPM range? Is that a safe comment to make? Is it even more applicable to say this with AFR 205 heads as well?
yes. here's my dyno from the wife's car stock cam, no tuning, added the crane 1.8 accelerated lift rockers and dual springs.
Old Feb 23, 2007 | 01:28 AM
  #35
knkali's Avatar
knkali
can someone help me understand which line is what? Or which color is what?
Old Feb 23, 2007 | 06:06 PM
  #36
mrr23's Avatar
mrr23
St. Jude Donor '15
run 009 - dark blue = hp lt blue =tq before rockers
run 011 - red = hp pink = tq after rockers 500 miles
run 14 green = hp black = tq 10 months later
Old Feb 23, 2007 | 06:52 PM
  #37
knkali's Avatar
knkali
MRR23,
why the increase after 10 months?
how is the torque BELOW 3K rpm. Cannot tell from graph. Did it suffer after the rockers?
To roller rockers
Old Feb 23, 2007 | 08:24 PM
  #38
knkali's Avatar
knkali
In red is that 387 ft lbs or ?? The red line is not above the black one so how could that # be higher than the blk line max number?
Old Feb 23, 2007 | 08:40 PM
  #39
mrr23's Avatar
mrr23
St. Jude Donor '15
MRR23,
computer learn main reason. can't say it was the weather. it was way hotter 10 months later.
made it better. one thing with an auto car with a stock converter. up until about 3000 rpms, it feels sluggish. right at 3000 rpms, the motor starts picking up. the rockers brought this down to around 2500 rpms.
look to the very left. you'll see a spike on the graph. that can happen sometimes. which is the reason why you look at the whole graph.
here's my timeslips also.
before rockers
after rockers
Old Feb 23, 2007 | 08:56 PM
  #40
knkali's Avatar
knkali
thanks for the help
