B&M Ripper
Old Feb 7, 2007 | 08:35 AM
ken-rx's Avatar
ken-rx
Default B&M Ripper
CHanged the shifter to a Hurst and it still rattles between 2 and 4000 Rpm. Althought better then the stock one its still annoying. Anyone have a B&M? Does it make noise ?
Old Feb 7, 2007 | 08:45 AM
NTRBL33's Avatar
NTRBL33
From: The United States of TEXAS www.corvettemotorsportsinc.com
St. Jude Donor '07-'08-'09-'10-'11
we greased the snot out of the shifter plus put a thicker gasket between the shifter & trans
no rattle here
Old Feb 7, 2007 | 12:15 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I installed the B&M and don't have any rattles. Very minor vibration.
Old Feb 7, 2007 | 12:55 PM
goatts's Avatar
goatts
Have B&M. Works great. Put synthetic grease on mechanism when installing.
Old Feb 7, 2007 | 03:12 PM
IC6's Avatar
IC6
i think the increased vibration from firmer bushings is rattling the **** on mine... i'm going to try to fiddle w/ a sound deadener between the shaft and the ****...
Old Feb 7, 2007 | 05:39 PM
srm248's Avatar
srm248
no rattle here
where did you get the thicker gasket from? i tried getting a replacement gasket from my local dealer and he said it couldn't be ordered by itself.
Old Feb 7, 2007 | 05:41 PM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
B&M here...no noise.
I hear you can pack the springs areas with grease to quiet the rattling. Hear is a thread where someone else with a Hurst fixed his noise a different way, you can get a 1.5 pvc cap for a about a buck:
http://forums.corvetteforum.com/show...ighlight=hurst
Old Feb 7, 2007 | 06:58 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Literally, booger bushings make anything for this shifter? I looked at their website, appparently not so. But, if you give them a call, they may have something that'll work.
I know on the cars that they put them on, it works wonderfully to firm things up and keep it from rattling. May be a less expensive route than replacement.
Old Feb 7, 2007 | 11:04 PM
NTRBL33's Avatar
NTRBL33
we bought a generic gasket from oreily's and trimed it to fit.
To B&M Ripper
