Stock RWHP C6?
Old Feb 10, 2007 | 01:37 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
Default Stock RWHP C6?
Just wonderd what the average Stock RWHP is on a C6 a6? I hear around 340hp. Wonder if anyone is getting 360 stock to the wheels.
Old Feb 10, 2007 | 01:50 PM
Turbooo2u's Avatar
Turbooo2u
If you could put every stock C6 on the same dyno, I figure that would be about the average.....340.
Old Feb 10, 2007 | 02:29 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
http://forums.corvetteforum.com/show...post1558764087
http://forums.corvetteforum.com/show...highlight=dyno post #146
Most of these are manuals however, and its not uncommon to see high 340s, low 350s. But the automatics should not be too far behind. Mine is a manual, and with very few miles on it (less than 2K) and fresh off the interstate following a 20+ mile trip to the speed shop, and then right straight onto the dyno, less than 10 minutes off the road, came in at 340 on the nose, smoothing at 5 and SAE corrected,.
Had it been cooler and and better broken in, who knows?
If you are into quarter mile results, the quickest bone stock quarter mile time reported on this forum was run by forum member LS1 LT1 in an A6.
Old Feb 10, 2007 | 05:53 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
Thanks for the help!
Old Feb 10, 2007 | 06:03 PM
07MontRedcp's Avatar
07MontRedcp
Mine dynoed at 349/349 bone stock W/3338 miles on the engine.
BJK
Old Feb 10, 2007 | 08:06 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
[QUOTE=07MontRedcp;1558902819]Mine dynoed at 349/349 bone stock W/3338 miles on the engine.
The reason i asked, i took my C6 a6 to a dyno shop that offerd three pulls for $50,00. The shop had never done a C6 or a any Vette for that matter. They were kinda lost doing my C6, the numbers came out to 305 RWHP , this was not done on a dynojet. They said add around 12% to the 305 rwhp if it was done on a dyno jet.
Who knows, i'm new to the dyno thing.
Old Feb 10, 2007 | 10:21 PM
07MontRedcp
Get your reading glasses and spend some time reading this link:
http://www.msprotege.com/forum/archi...123629978.html
BJK
Old Feb 11, 2007 | 03:06 AM
Evilways's Avatar
Evilways
I wouldn't let anyone use my car as a test subject and pay them $50.00 for it. Don't take your car to anyone who doesn't know the car. It sounds like these folks didn't even know their own dyno . My 06 A6 was 337 at the wheels stock. 305 is totally sofakingwetoddid
Old Feb 11, 2007 | 07:37 AM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
Wished i knew they never did a C6 before i went, they do alot of imports and stangs.
They said add around 12 to 15% to the 305 hp figure if it were done on a dynojet.
Chas
Old Feb 11, 2007 | 11:13 AM
Evilways's Avatar
Evilways
my flywheel to rear wheel loss is 16.5%
Old Feb 11, 2007 | 01:49 PM
Wayne88's Avatar
Wayne88
I think thats the average, about 17% difference.
Old Feb 11, 2007 | 01:54 PM
vetterlatethannever's Avatar
vetterlatethannever
Chas
They don't know what their own dyno is
Old Feb 11, 2007 | 02:10 PM
achilds's Avatar
achilds
Mine was 353 rwhp and 351 rwtq bone stock with about 3500 miles. It is a stick.
Old Feb 11, 2007 | 02:22 PM
BADC64GO's Avatar
BADC64GO
Enough
Old Feb 11, 2007 | 03:50 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
Well if ya add around 15% to my 305 figure it should about the norm.
Old Feb 11, 2007 | 05:56 PM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
BJK
So much for dyno braggin dudes..I prefer laptop real world tuning..
Old Feb 11, 2007 | 06:02 PM
Evilways's Avatar
Evilways
No, no...your car should be as listed if stock, meaning 400 BHP (at the flywheel. You take approx 15-17% from that and it's what should be at your rear wheels. The 15% they told you would be what you lost from engine to rear, which would put you at 350.75BHP(flywheel), not the 400bhp your car is supposed to have.
To Stock RWHP C6?
Old Feb 11, 2007 | 06:03 PM
cbrf4i1's Avatar
cbrf4i1
no, it won't be....it would only you around 360 crank hp. your dyno shop has no clue about heat soak in the ls2. i am sure when they dyno it, your iat and ect was way up there to cause pcm to pull timing.
Old Feb 11, 2007 | 07:37 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
Well i will take it to another shop that knows C6's, and end this story once and for all!
Old Feb 11, 2007 | 09:43 PM
NORTY's Avatar
NORTY
Automatics usually pull about 325 on the ground when stock.
