Clutch problem ???
Old Feb 11, 2007 | 09:17 AM
PaulC6Z's Avatar
PaulC6Z
Default Clutch problem ???
Hey Guys,
I'll try to be as clear as I can maybe one or two of you willl be able to explain to me what happened. Sat. morning I met up with some friends. I had to drive about 7-8miles to the meeting spot. I drove slowly 2500rpm's no more car was warmed up. I got there first. I decided that I wanted to do a burnout. So, I revved the engine to 3.5k-4krpm's pushed the clutch in, put it in 1st, and let her rip. Here is where my problem starts. Nothing happened I was standing still and the engine revs continued to climb. I immediately pushed the clutch back in and let off the gas pedal. I found the clutch stuck on the floor. The pedal had come back up. I let the revs drop put it in 1st and parked. I got out and noticed a burning smell. The good news is that the car drove fine after the incident. What happened? How bad? What do I do so it never happens again? Thank you all in advance.
Old Feb 11, 2007 | 09:45 AM
TN 2005 C6's Avatar
TN 2005 C6
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
I'm no expert but, I would read the message in the link provided. This may be your problem. Hope it helps. http://corvetteactioncenter.com/kb/q....php?qstId=562
Old Feb 11, 2007 | 02:55 PM
calemasters's Avatar
calemasters
I had the same concern on my 2005. Had the dealer do DTB 05-07-31-001A, and the new clutch fixed the concern.
Old Feb 11, 2007 | 03:05 PM
sofgl's Avatar
sofgl
My 2006 Z51 did the same thing and guess what they found? Hey! It did not fall within the number range for replacement!! I replaced it anyway and the mechanic said afterward I should have gone with a heavier aftermaket clutch. Pisses me off GM won't recognize it is a problem in all the cars.
I still love my car though.
Old Feb 11, 2007 | 05:37 PM
LOS ANGELES PI's Avatar
LOS ANGELES PI
Too bad.
Would have been one hell of a burnout.
Old Feb 11, 2007 | 08:01 PM
Hoonose's Avatar
Hoonose
Sometimes gunky clutch fluid can cause this. It's easy to replace. Do a search for forum member Ranger for the particulars.
To Clutch problem ???
