New Cam Install, Lsa Advice
Old Feb 13, 2007 | 11:05 PM
DONALD HALL's Avatar
DONALD HALL
Default New Cam Install, Lsa Advice
Hi All
I am having MTI in Houston install a C2 cam in my C-6, 6-speed,headers,high flow cats, vararam intake, underdrive crank pulley, Borla touring. They are doing before and after numbers. The install will include pushrods and springs and tune. The cam numbers are 224/224 .581/.581. The question is, they gave me a choice of 112 or 114 lsa. They said the 112 would be a little more lumpy no info as to the performance difference. Any opinions?
Thanks all
Old Feb 13, 2007 | 11:27 PM
vr6aaron's Avatar
vr6aaron
id go with 114, this will still give you cam sound but not be as harsh.
Old Feb 13, 2007 | 11:32 PM
DONALD HALL
Default Thanks
Thanks for the info, aaron.
Old Feb 14, 2007 | 12:43 AM
glennhl's Avatar
glennhl
Manual Trans: 112 LSA
Auto Trans: 114 LSA
(you said you had a 6 speed, but so do I, but it's a 6 speed automatic)
Old Feb 14, 2007 | 01:20 AM
LATE LIFE TOY LOVER's Avatar
LATE LIFE TOY LOVER
Originally Posted by DONALD HALL
Hi All
I am having MTI in Houston install a C2 cam in my C-6, 6-speed,headers,high flow cats, vararam intake, ,underdrive crank pulley Borla touring. They are doing before and after numbers. The install will include pushrods and springs and tune. The cam numbers are 224/224 .581/.581. The question is, they gave me a choice of 112 or 114 lsa. They said the 112 would be a little more lumpy no info as to the performance difference. Any opinions?
Thanks all
Still learning!! What is a "underdrive crank pully"?
Old Feb 14, 2007 | 06:01 AM
gtodoug's Avatar
gtodoug
I would do the 112lsa if you don't mind a little lumpier cam. It will bring the power on sooner and have some more power under the curve.
Dougie
Old Feb 16, 2007 | 01:23 AM
DONALD HALL
Default Thanks all
Thanks for all the advice. I do have a 6-speed manual and I am looking for the most power with my set-up. I think the 112 lsa is the one to go with.
Donald
Old Feb 16, 2007 | 02:10 AM
jogar80's Avatar
jogar80
When will it be done. Make sure to take some video PLEASE!!!
Old Feb 16, 2007 | 11:05 AM
RWSjr's Avatar
RWSjr
Dougie
I thought it was the other way around, bigger lsa moves the powerband to lower rpm's.
Old Feb 16, 2007 | 04:19 PM
Z06Norway's Avatar
Z06Norway
me to
Rune
Old Feb 16, 2007 | 04:24 PM
SpinMonster's Avatar
SpinMonster
wider LSA moves the power band up and lowers the low to mid power in favor of a bigger peak number.
With a small 224 cam there will hardly be a difference. The dcr will be slightly higher so guys looking to leave the heads alone will be better off opting for the 112 even with an auto.
To New Cam Install, Lsa Advice
