Just finished pinning the crank. I do not see where it says how much torque I need to put on the bolt when putting it back in. Does anyone know how many ft lbs it should be.
I asked the same question re. the C-5 a few months ago. Got only one answer, it was 240 ft-lbs. Sounds reasonable to me.
I have a call in to a friend that is a mechanic with all the chevy tech computers and he is going to try and look it up. If he finds something I will post it.
1 - Tighten the used crankshaft balancer bolt to 330 N·m (240 lb ft).
2 - Remove used bolt and tighten the new crankshaft balancer bolt a first pass to 50 N·m (37 lb ft).
3 - Tighten the new crankshaft balancer bolt a second pass to 140 degrees
The easiest way to determine the 140 degrees is to run the initial torque reading, then mark zero straight up on the bolt head, then, using your kids protractor, mark 140 degrees on the balancer. When the two marks align, you've hit the 140 degrees necessary. But, good luck in reaching that mark. I got to around 100 degrees, and just could not get any further, even with a 4 foot length of pipe as an extension. I loaded the bolt with red Locktite, so I hope it will be enough. It's gone approx 2000 miles since the install with no issues. It's a real PITA. Good luck.
You are correct regarding an OEM installation, but if the balancer is pinned, tightening the balancer that tight is probably not really necessary since the pin is preventing the balancer from turning on the crank. The OEM method is necessary to ensure there is enough friction between the balancer and crank to prevent turning, since the friction is the only thing that prevents the balancer from turning on the crank.
