tire math ?
Old Feb 14, 2007 | 02:18 PM
meaniam's Avatar
meaniam
Default tire math ?
Sidewall Radius Diameter Circumference
3.7in 13.2in 26.4in 83.0in
4.0in 13.0in 26.0in 81.8in
my question is diameter total highet of wheel
and circumfrence is the same as if i took a piece of string and brought it around the outside that would be my circumference
and diameter is width of tire (footprint)
is this all correct
Old Feb 14, 2007 | 03:04 PM
dennis50nj's Avatar
dennis50nj
is this all correct
www.1010tires.com go to tech section then tire size calculator
Old Feb 14, 2007 | 03:13 PM
dbratten's Avatar
dbratten
is this all correct
1) my question is diameter total highet of wheel -- total height - yes, in this case.
2) and circumfrence is the same as if i took a piece of string and brought it around the outside that would be my circumference -- yes, circumference or how far your tire travels in one rotation.
3) and diameter is width of tire (footprint) -- no, see #1.
Say you have a 245/35/18 tire --
245 is the width in millimeters (mm).
35 is the aspect ratio -- meaning what percent of the width is the sidewall height -- in this case 35%.
18 is the tire (and wheel) diameter.
To find the width of the tire in inches divide 245 by 25.4 (the number of mm to an inch) -- 245 / 25.4 = 9.65 inch.
The sidewall height is 9.65 inch times .35 (35%) -- 9.65 * 0.35 = 3.38 inch.
The diameter of the tire (and total height of your wheel) is 3.38 inch times 2 (you have to count top and bottom sides of the tire) plus the rim diameter -- 3.38 * 2 + 18 = 24.75 in.
Circumference is diameter times pi or in this case -- 24.75 * 3.1416 = 77.75 inches.
--Dan
Old Feb 14, 2007 | 09:25 PM
haljensen's Avatar
haljensen
--Dan
Good answers but the question of "footprint" can't be answered with stated tire measurements. The formula above is for width of the tire at the SIDEWALL, not the tread width and it seems as if every tire manufacturer measures different. Some 285 tires have more tread on the pavement than some 295's.
Old Feb 14, 2007 | 09:54 PM
meaniam's Avatar
meaniam
thank you to all the repys. in my situation i went with a 295 35 19 on a zo6 19x12 rim it does not work it looks like a$$. so if you read this and have a z06 or are doing a widebody wait and ill post pictures the rear tire crowns way to much. pulling proably at least 1/2 of total hiegth or more
Old Feb 14, 2007 | 10:09 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
I think that's what dennis50nj (the first person to answer) was trying to tell you. The 1010 Tires calculator shows 11.5" as the widest wheel for a 295mm tire (and even that is a bit wide for a 295 IMO).
The calculator isn't perfect. For example, it shows the stock C6 Z06 size as "unknown." If it shows that a wheel is too wide or narrow for a given size, you can trust it though.
GL!
Old Feb 15, 2007 | 04:37 AM
2LT-Z51's Avatar
2LT-Z51
you could put a piece of tape on the ground mark it and the tire...
make one revolution put the second tape down and mark it.... (at the first mark from tire)
measure the distance of the two tape marks and divide that by 3.14 and it will give you a "loaded" diameter (what the car actually sees)....
the numbers will be different if say the tire was close to flat... (smaller diameter) or over-filled (larger diameter)...
as far as "footprint" goes - (part that touches the ground)... a tire will have a larger foot print if it flat...
and of course the opposite is true if over inflated.... (same size tire)
sorry.... very general - quick explanation.....
Old Feb 16, 2007 | 08:49 PM
meaniam's Avatar
meaniam
thanks to all those who chipped in on this topic
Old Feb 16, 2007 | 10:09 PM
dennis50nj's Avatar
dennis50nj
anytime
To tire math ?
