Clutch problems - C6
Old Feb 16, 2007 | 01:37 AM
rampage76's Avatar
rampage76
Default Clutch problems - C6
I bought my new C6 about 7 months ago. A few weeks ago, I noticed that the clutch appeared to slip in gears 3-6. When I was in one of these gears and I gave it some gas, the RPM would rise and then settle to what it should be (you could hear the engine rev up and then settle). I assume this is the clutch slipping but it might be something else.
I took it to the dealership this week and they have said that the clutch is burned and it is not covered by the warranty. I called Chevy Customer Care today and opened a case but they are saying the exact same thing as the dealership. They consider this to be a "wear and tear part". The estimate for the repair is $1,650.
I only have 6,000 miles on the car and I don't race or drive aggresively. Also, most of the miles are highway miles. My other car is a 2000 Camaro SS and I have not had any issues with its clutch in 7 years. Does anyone have any idea what I can do about this? Is it common? 1,650 is a lot of money to pay for a new clutch after 7 months on a new C6.
Old Feb 16, 2007 | 02:00 AM
Matt O's Avatar
Matt O
Do a search on this, I understand there is a problem with the clutch "sticking". Don't know if this your problem but many C6 owners are changing the fluid in the clutch master cylinder every time they change the oil. I looked at a 05 with 5k miles before I bought my 07 auto and the clutch was sticking and not returning all the way up when I tried to drive it. The dealer took it in the shop and said it would take a week to fix it. I went to another dealer and bought an 07.
The only other question I would have is did you leave the car at the dealer for service and have some tech screw it up. Good luck!
Old Feb 16, 2007 | 06:09 AM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
Sorry about your clutch issue...My 05 6mz z51 has 16500 miles, and a lot of the miles were spirited driving and launches, so far not even a hint of fade. Sounds like you have a defective clutch, or flywheel. There is a possibility that the fly wheel has glazed too, due to some inherent defect. Really, no way to tell unless you inspect these parts by removal..
Old Feb 16, 2007 | 07:01 AM
Goodwood's Avatar
Goodwood
Did you break it in gently over the 1st several 100 miles? That could definitely be the cause of premature slippage.
Old Feb 16, 2007 | 11:03 AM
rampage76's Avatar
rampage76
No Comment. However, this problem did start with the clutch sticking and I am guessing that the sticking was the result of a defect. The burning was a result of the sticking.
Old Feb 16, 2007 | 11:37 AM
Chevtech's Avatar
Chevtech
Either there is more to the story or the Dealership is going overboard! While abuse of the car Isn't covered, unless there is clear signs of abuse a clutch would be replaced under warranty. It would also be uncommon for it to only slip in 3-6, and not in first and second gears. Now, if you came back again with a problem then it would lead to a driving condition more then a car issue. This is another good example of why its good to build a relationship with your dealership, trust on both sides goes a long way to smooth things out.
Old Feb 16, 2007 | 11:55 AM
rampage76's Avatar
rampage76
There really isn't any more to this story. I do have a decent relationship with the dealership and my service advisor. The problem is that chevrolet does not cover this part in the warranty. It is even listed in the owners manual. Can we suspend making a lesson out of my situation until after I can figure out how to resolve it? I was hoping for advise as opposed to condescending remarks.
Old Feb 16, 2007 | 12:03 PM
Chevtech's Avatar
Chevtech
Believe me, we have changed many clutches under warranty, even when it was pretty clear abuse was involved, ie: rubber in the wheel wells, bald tires, etc. Its covered unless they tell you why not, and normal driving would not cause a clutch to slip in 6k miles. Wasn't trying to be condescending at all, good luck.
Driver_WT's Avatar
Driver_WT
St. Jude Donor '07
I had a similar problem with my 05 c6 at 7000 miles. Turns out the pressure plate was defective and it was replaced under warranty (new clutch and pressure plate) - no charge to me.
Old Feb 16, 2007 | 02:50 PM
rampage76's Avatar
rampage76
I'm calling the dealership from where I bought the car. They are saying that the diagnosis I've been given sounds strange. Looks like I will get a second opinion.
Old Feb 16, 2007 | 06:14 PM
d3miller's Avatar
d3miller
I've had many clutch issues as well. It was good for the first few thousand miles, but has gotten progressively worse since. Just feels like crap and really rough going through the gears, especially the first 3. Sometimes VERY difficult to just put it into first. I've taken it in maybe 4 times, the 3rd time in they said I need new master & slave cylinder, which they replaced under warranty. Problem still there, took it in again a few months ago and they said they "made some adjustments". Still feels like crap. Going to take it in again next week. I have about 16k miles on it...
Old Feb 16, 2007 | 09:02 PM
rampage76's Avatar
rampage76
I'm sorry to hear that. I ended up takin gmy car to the other dealership. They said that they found a bulletin that matched my VIN regarding the flywheel. They think all the repairs will be covered by this.
My question is how in the heck did the other dealership and even Chevrolet customer care not mention this to me? I find it hard to believe that they wouldn't check this before telling me that I was responsible for the repair.
Old Feb 17, 2007 | 02:38 PM
goatts's Avatar
goatts
The car is built for spirited driving. It's a vette. Can't imagine anything causing the clutch to wear out that fast short of defect. You may need to press the issue. Have you talked to the manager of the dealership where you bought the car? Let us know the outcome.
Old Feb 17, 2007 | 04:19 PM
ourayzman's Avatar
ourayzman
Rampage76 - Good to hear you may get this resolved under warranty due to the bulletin. It may be helpful to many of us to know the bulletin number for the clutch problem if you can find out. I have an 06 with about 6,000 miles and although no clutch problems yet, one never knows!
Old Feb 17, 2007 | 10:32 PM
Byrdguy's Avatar
Byrdguy
There is a bulletin about sticking clutches. Has to do with defective machining of the flywheel. Just complain about it sticking on occasion.
To Clutch problems - C6
