when i press any of the dic info buttons there is like a radio static sound for a sec. is that normal?
also how do you pull codes in the c6, i tried the options fuel like in the c5 but did not work
Shouldn't be a static sound. There should be a beep through the left radio speakers when you push one of the buttons.
You can't pull codes via the DIC on a C6. You need a CAN (Car Area Network) enabled code reader. Walmart has one for $79 that works. Be sure the tool is CAN enabled, an ordinary OBDII reader won't work with the C6.
Very faint, but when the radio is off, you can hear very faint static through the speakers before the beeps from the DIC, or seat memory, anything that produces an audible beep, you will hear the faint static too. I'm guessing this is normal, just need to listen closely.
From: Central Florida. Black Sheep Squadron Member. 465 rwhp & 477 rwtq
Cruise-In VIII Veteran
St. Jude Donor '07
I can hear it as well, I think it's normal though.
