B&M Shifter Rattling
Old Feb 21, 2007 | 11:53 PM
jdenny21's Avatar
jdenny21
Default B&M Shifter Rattling
I just installed the B&M shifter that was delivered today, the install was easier than I expected, only took about 40 minutes or so.
So I take my C6 Z51 out for a spin to check out the new shifter; shifts were noticably shorter, more precise and notchier feeling. I loved the way it feels compared to the factory shifter.
I did not notice it at first b/c my windows were down, but when I rolled up the windows, I noticed that the shifter rattled quite a bit under hard throttle, especailly at low rpm, say 4th gear, full throttle, going about 40mph. The rattle was pretty loud and annoying. I noticed that the rattle seemed to stop when I gripped the shifter firmly which leads me to believe the rattle is caused by the connection between the factory shift **** and the B&M shifter.
Tomorrow I will probably take the shift **** off and drive it to see if that stops the rattle and hopefully isolate the issue. (fingers crossed that this is the culprit).
If it does turn out to be the shift **** which I believe it is (again hopefully), anybody have any ideas as to rememdy the rattle? I know a threaded shift **** would probably be the best remedy, but I kinda what to keep the factory ****.
Think teflon tape would help? Anything to tighten the gap between the shifter and the ****?
By the way, the screw that secures the **** is securely tightened.
Anyone else had this problem?
Thanks for the help.
Old Feb 22, 2007 | 07:33 AM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Teflon tape works. Ive also see a few guys use RTV silicone. Either one will make insulated the stock **** and can be removed if necessary.
Old Feb 22, 2007 | 08:34 AM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
exact reason I removed the B&M and went with the Callaway shifter
Old Feb 22, 2007 | 01:11 PM
ErnieD's Avatar
ErnieD
St. Jude Donor '16-'17,'19
According to info on this forum, GM is scheduled to offer a replacement "button" that snaps onto the ball at the bottom of the shifter. This button is reputed to be the source of the rattle that many experience.
I've "played around" with both rattling B&M and stock shifters, with varying degrees of temporary or partial success, and I'm inclined to think that this new button is the best shot at a fix.
Old Feb 22, 2007 | 10:22 PM
thomas walters's Avatar
thomas walters
I have the same issue with third gear. I tried the teflon tape solution as well as the Lithium Grease solution, but to no avail. I have the Hurst short throw plus a Hurst pistol grip ****.
I hope SMKN 07 is correct and there is a GM solution on the near horizon, because I like the Hurst package I purchased, with the one exception being the rattle in third gear while under moderate to heavy acceleration.
Old Feb 23, 2007 | 01:06 AM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
We installed a Kirban shifter on our 07 and it rattles under hard acceleration too!
Old Feb 23, 2007 | 04:00 PM
timd38's Avatar
timd38
I bought his old B&M and it does rattle, sometime, so I just make believe that I am in a late 60's muscle car......
Old Feb 24, 2007 | 10:40 AM
goatts's Avatar
goatts
I put synthetic grease on mine when assembling it and it's worked fine. No complaints.
Old Feb 24, 2007 | 01:33 PM
TT DSOM's Avatar
TT DSOM
Same problem with mine, switched out for a Hurst
Have heard good things about the Callaway as well, but the B&M is known for the "rattle"
Id go with the hurst
Old Feb 24, 2007 | 01:53 PM
timd38's Avatar
timd38
FYI, Hurst was purchased by B&M........
To B&M Shifter Rattling
