normal oil temp
Old Feb 26, 2007 | 04:25 PM
boostfedtruck's Avatar
boostfedtruck
Default normal oil temp
What is the normal operating oil temp that you guys are seeing on your c6.I just bought a brand new 07 with 600 miles on it and im seeing 210 and 220 when its been sitting still. Thanks Ryan
Old Feb 26, 2007 | 04:29 PM
officerp's Avatar
officerp
I have 1400 miles on my 07 and mine reads about that.
Violet's Avatar
Violet
...that's about where our '05 settles when it's warmed up (around 210* - 215*).
Old Feb 26, 2007 | 04:36 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Old Feb 26, 2007 | 04:49 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
This weekend, at 65-70 mph in sixth gear (~1700 rpm), ambient temperature around 50 degrees, I saw 213-216 degrees oil temperature, coolant temperature 196-198 degrees, and oil pressure 37-39 psi.
Old Feb 26, 2007 | 06:31 PM
VET4LES's Avatar
VET4LES
I see 214 while cruising most of the time in normal weather.
Old Feb 26, 2007 | 07:17 PM
boostfedtruck
Thanks guys, just making sure everthing is the way it should be.
Old Feb 26, 2007 | 09:23 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
On longer drives i am around 214, in my 06 a6. Most days i dont get over 110 since i am one mile from work.
Old Feb 26, 2007 | 11:28 PM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
I installed the 160 stat and had a tune done, the temp average is around 178-185 average driving, and oil temp is 198-205.
However with the stock set up your numbers are on par.
Old Feb 27, 2007 | 01:46 AM
2006c6keller's Avatar
2006c6keller
I find my 06 c6 a6 oil temperature about 20* degrees higher than coolant temperature, coolant temperature runs 200*.
Old Feb 27, 2007 | 02:02 AM
LATE LIFE TOY LOVER's Avatar
LATE LIFE TOY LOVER
Default higher is ok
above 212 is good. it keeps the moisture cooked off. below that moisture forms and that combines to make acids, thats bad. never getting to full operating temp is real bad..
Old Feb 27, 2007 | 05:12 PM
07C6NTX's Avatar
07C6NTX
Old Mar 19, 2007 | 04:06 AM
mwvettec5's Avatar
mwvettec5
Mine was EXACTLY the same after a 45 minute drive today with the very same outside air temp !!!
Old Mar 19, 2007 | 04:49 AM
StarJack's Avatar
StarJack
Cruising, the coolant is around 180 and the oil just under 200. Rabbit starting and city driving push both those numbers up 5/10 degrees.
To normal oil temp
