A stiff gear shift
Old Mar 4, 2007 | 05:50 AM
ROD BROWN's Avatar
ROD BROWN
Default A stiff gear shift
I have a 06 Vette and the gear shift is very stiff to shift.Any suggestions on how I can make the shifting smoother.It bucks only going into second, The other gears are stiff and really hard to speed up the shifting process.Oh,this is a stick shift
Old Mar 4, 2007 | 08:44 AM
Max@Cartek's Avatar
Max@Cartek
Sometimes you get that if you don't depress the clutch enough on your shifts or you take too long between shifts. Just some thoughts. You may have a problem with the car, but check to make sure you are doing these things first.
Old Mar 4, 2007 | 11:29 AM
ROD BROWN's Avatar
ROD BROWN
Default I'll try it!
I am pretty sure I have the clutch in far enough,but I will be aware of this possible solution and maybe it is the cure.Thank you for the heads up. Rod
Old Mar 4, 2007 | 06:21 PM
REVAK's Avatar
REVAK
I had same problem when car or temps were cold. A search will show many great suggestions on improvements that are available. Such as ....ROYAL PURPLE syncromax in trans,.....fresh dot 4 clutch fluid... check it out, I saw a major improvement in shifting with these forum ideas. Also check out the 'anti venom" mod for the trans.....
Old Mar 4, 2007 | 06:28 PM
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
Try RP in the tranny and rear. Worked for me!
Old Mar 4, 2007 | 07:21 PM
BlueSpeed's Avatar
BlueSpeed
I went further and installed a B&M short shifter, you can look up my review in a prior thread
Old Mar 4, 2007 | 07:51 PM
6 speed Sid's Avatar
6 speed Sid
It works better when hot, but mine is still notchy. It's about typical for a Vette shifter, but I believe it could have been designed to be somewhat smoother.
Old Mar 5, 2007 | 01:49 AM
07MontRedcp's Avatar
07MontRedcp
ROYAL PURPLE SYNCROMAX. You won't believe the difference.
BJK
Old Mar 5, 2007 | 08:05 PM
ROD BROWN's Avatar
ROD BROWN
Default Where do I buy it?
BJK
I have never heard of Royal Purple Syncromax. where can I purchase this product? Rod
Old Mar 5, 2007 | 08:50 PM
BlueSpeed's Avatar
BlueSpeed
PM sent.
Old Mar 5, 2007 | 11:28 PM
07MontRedcp
Pep Boys is one source. This product is well know by many on the forum.
BJK
To A stiff gear shift
