Lowering bolt accessibility....
Old Mar 7, 2007 | 06:09 PM
SPANKY LS1's Avatar
SPANKY LS1
Default Lowering bolt accessibility....
I am going to swap my new wheels and tires on the car, if I jack the car up by the jacking points using pucks (one corner at a time) will I be able to reach/turn the bolts from each wheel opening pretty easily?
Thanks, Shawn
Old Mar 7, 2007 | 06:22 PM
dennis50nj's Avatar
dennis50nj
Thanks, Shawn
just jack it in the middle in the rear and the front on the craddle the bolts are right there within easy reach
Old Mar 7, 2007 | 07:33 PM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
The bolts will still be difficult to turn because there is still tension on the spring. I'm not sure if you'll be able to turn it or not like that.
Old Mar 7, 2007 | 07:36 PM
SPANKY LS1's Avatar
SPANKY LS1
I thought if the wheel/tire was "hanging" the tension would be off the spring?
Old Mar 7, 2007 | 07:48 PM
Larry Gonzalez's Avatar
Larry Gonzalez
Default Lowering bolts
I put stands under the car and with a jack, lifted the side of the spring where I was going to turn the bolt I then could easily turn it by hand, make sure you measure so that the car is level!
Have FUN
Old Mar 7, 2007 | 08:52 PM
mlongo99's Avatar
mlongo99
Nope, there's still a bit more travel left in the spring, so there will be tension, just less of it. You could try it though, it might work. But you won't be able to turn it by hand.
Old Mar 7, 2007 | 09:39 PM
dennis50nj's Avatar
dennis50nj
i didn't even jack it up i just got under the back of the car and turned it with a ratchet. i only did the back
Old Mar 7, 2007 | 10:49 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
If you do not take the tension off the spring you can destroy the bushings on the bottom of the bolts. It seems you cannot buy new factory bolts without buying the whole spring.
Old Mar 7, 2007 | 10:51 PM
mlongo99's Avatar
mlongo99
Well I guess that works then!
The back sure is easy. I jack up the spring a bit, but it's nice to just be able to reach right under there without lifting the car at all.
To Lowering bolt accessibility....
