Header Bolts?
Old Mar 7, 2007 | 09:17 PM
jdenny21's Avatar
jdenny21
Default Header Bolts?
I recently purchased a used set of LG headers and was wondering if I could use the factory manifold bolts to secure the headers to the engine block. I think I probably will use the factory gasket as it is metal, but not sure if I can use the factory bolts for the LG Headers. I am planning on doing the installation tomorrow evening, so please respond if you know.
Also, if you cannot use the factory manifold bolts to secure the LG headers to the block, where can these bolts be obtained?
Thanks a ton for your help.
John
Old Mar 7, 2007 | 09:50 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
John
The factory bolts can be used.
Old Mar 7, 2007 | 09:55 PM
Miaugi's Avatar
Miaugi
....and don't forget to use anti-seize compound on the bolts, available at any auto parts store.
Old Mar 7, 2007 | 10:38 PM
jdenny21's Avatar
jdenny21
Default Thanks for the help
Thanks for the quick replies....I was worried I wasn't going to be able to do this tomorrow evening b/c my mechanic buddy said that sometime headers need special bolts...
I already picked up some anti seize and a o2 sensor socket in response the the very helpful members here.
Thanks again, I will let you know how the install goes, should be painless I hope, my mechanic buddy is helping me.
Old Mar 7, 2007 | 11:56 PM
m_LeDez's Avatar
m_LeDez
From: Houston, Tx.....'05 Corvette M6 LS3 Magnuson Heartbeat
Here's a link for a step-by-step install for Kooks headers. Might be helpful for a visual reference.
http://www.corvettemagazine.com/2005...kooks-lead.asp
Good luck!
Old Mar 8, 2007 | 03:50 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Old Mar 8, 2007 | 07:17 AM
Miaugi's Avatar
Miaugi
Good luck!
Good link, thanks!
I will be installing a set of Kooks soon and I'm sure to be reviewing this article.
Old Mar 8, 2007 | 07:35 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
if bolts didn't come with the headers the stock ones can be reused.
don't forget to retorque them after a few heat cycles.
Old Mar 8, 2007 | 08:37 AM
BC Bob's Avatar
BC Bob
I reused the OEM bolts. Buffed off the factory antiseize and reapplied new. Also reused the OEM gasket. While everything was apart, I also pulled the plugs and applied antiseize to them.
Old Mar 9, 2007 | 07:06 PM
openhelix's Avatar
openhelix
I used stage 8 bolts for a few reasons. One being supporting a local business. But more importantly I know they're not going to move or back out. They also look really cool
Old Mar 9, 2007 | 08:18 PM
1vetteracer's Avatar
1vetteracer
I would highly recommend using Stage 8. The best secure way to mount headers.
To Header Bolts?
