Cam affect on reliability/longevity?
Old Mar 10, 2007 | 07:34 AM
Max@Cartek's Avatar
Max@Cartek
Originally Posted by StarJack
What duration/lift/lsa is the stock cam in the C6?
204/211
0.525 inch of lift
116 LSA
Old Mar 10, 2007 | 07:41 AM
StarJack's Avatar
StarJack
Originally Posted by Max@Cartek
204/211
0.525 inch of lift
116 LSA
Thanks!!
Old Mar 10, 2007 | 08:20 AM
Max@Cartek's Avatar
Max@Cartek
Thanks!!
No prob.
Old Mar 10, 2007 | 10:14 AM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Originally Posted by Vet
...If you want max reliability and a full uncompromised warrantee, leave the car stock. If you want to mod, roll the dice and have fun... but if you approach it intelligently and aren't afraid to spend some bucks for top of the line parts and service, I'd think you'd be ok...
I'm well aware of the chances you take when modding. That's why this time I want to stay conservative and do it smart.
Originally Posted by LS1LT1
I wouldn't even bother changing the rockers, they could actually cost you power in some cases. The stock ones are fine until you go way up in power or certain forced induction applications but yes the better springs and retainers etc can actually increase reliability/longevity especially with the not so radical cams.
I wouldn't do rockers at all. No matter how much power I was making or what they were capable of. I've seen/heard too many horror stories about rockers failing and taking out the entire valvetrain. So they are not even a consideration for me. Sorry, just my own personal bias.
Depending on the size/specs of the cam it is possible that the valve springs might need to be replaced over time but what few people also realize is that even the factory stock springs with the stock cam (in LS1s, LS6s, LS2s etc.) go bad over time as well (especially with hard driving/high rpm use) and technically should be also be changed for maximum performance (ie: to avoid valve float).
But is the maintenance interval on aftermarket more frequent than stock?
Originally Posted by hiznhrz
Here's a thought, you can do far more damage faster with a moderately bad tune than with a moderately agressive cam (and top end).
True. But I have faith in my current tune and the shop I will use for the build (between two at this point) I have confidence in their capabilities.
Old Mar 10, 2007 | 12:05 PM
bunk22's Avatar
bunk22
There's a risk with anything. Now I did the rocker thing, my thinking was just a bit more power without going internal. Perhaps I'm one of the few but I used "supposedly" better springs, retainers, etc and a spring fails with less than 1000 miles on it. Granted I made more hp/tq across the rpm range but it almost cost me. I was lucky not to drop a valve or do any other damage. If I had to do it over, a cam and FAST intake is what I would have done. It would have come close to what I paid in the end for the rockers, install and breakage.
Old Mar 10, 2007 | 12:31 PM
LOS ANGELES PI's Avatar
LOS ANGELES PI
I am on the fence a little, but reading posts like this and others helps make up my mind. (Yes Joe, screw it. Its going in)
I am going AFR 205. Double springs, hardened push rods. A cam of 224/228 585 lift, LSA 114 and a three degree advance. And I dont know what the hell all of that means. But Im doing it.
Seems to be a reliable package worthy of about a 50 RWHP gain.
The seasoned folks tell me the thing to watch out for is the #7 cylinder as alot of turbulence occurs there and lean is not mean but a killer.
So, I am taking the advice of Tony at AFR and sending my injectors out to be flow tested and the one that flows the best, will go back into #7 and the next to #8.
I think as you approach 450 rwhp, things to think about is output shaft, clutch and other potential driveline issues.
But hey, isnt this all part of the fun?
Old Mar 10, 2007 | 12:39 PM
k0bun's Avatar
k0bun
I guess it depends on your opinion of "fun". I tell, you me and my wallet have had enough of that kind of fun. But in my research it appears that a not too aggressive cam coupled with the necessary supporting mods and upgrades will make for a good reliable street set up. I'm not looking for 450+rwhp. I'd just like 400+ and good driveability.
Old Mar 10, 2007 | 01:06 PM
knkali's Avatar
knkali
LA PI,
50 at the rear sounds very conservative with those mods.
Old Mar 10, 2007 | 03:52 PM
LS1LT1's Avatar
LS1LT1
Typically, yes it might be but again most people likely still think that their stock springs are operating just as well at 30k miles as they were at 1k miles when in fact they might not be holding up/causing some valve float at that point and are in potential need of replacing anyway. Of course the cost of stock springs is lower than the quality aftermarket ones.
The need to replace one's aftermarket springs after say, 30k or 40k miles is a relatively small price to pay for the performance gains achieved from executing a proper cam/spring/tune project IMO.
Old Mar 10, 2007 | 04:25 PM
k0bun's Avatar
k0bun
Good point. I just don't want to have to worry about the engine everytime I fire it up. Any idea how much it costs to replace the springs?
Old Mar 10, 2007 | 04:27 PM
LOS ANGELES PI
Well, then get a Z06 !!
Old Mar 10, 2007 | 05:02 PM
k0bun's Avatar
k0bun
Nah. I'd rather do some minor mods and make the car my own. Besides it'll be cheaper this way.
