Window Indexing
Old Mar 10, 2007 | 04:25 AM
So Cal's Avatar
So Cal
Default Window Indexing
I know how to index the windows but it seems as if I have been having to do this on an almost regular basis. A lot of the times when I go to shut the door with the window up its too high and hits the window seal, I re-index and the problem goes away temporarily.Am I doing something wrong or is this a common problem? By the way its a 05' base coupe, mn6
Old Mar 10, 2007 | 07:59 AM
timd38's Avatar
timd38
Sounds like the battery is getting really weak. If have had DBS issues, the battery may need to be replaced.
Old Mar 11, 2007 | 09:31 PM
SeeSikst's Avatar
SeeSikst
I have had same issue and have taken to shop on at least 6 occasions for correction. No luck in the end. Temporary fixes only. Now I just push the door shut with window instead of the door so it will index up properly. No issues when I use this approach when shutting door.
To Window Indexing
