Radiator drain plug
Old Mar 11, 2007 | 02:15 PM
MtnC-6's Avatar
MtnC-6
Default Radiator drain plug
I want to install a 160 thermostat today but don't see the drain plug. Doing it in the garage so visibility isn't the best even though it's raised up a bit.
Old Mar 11, 2007 | 02:34 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
You'll have to remove your radiator to install the thermostat and re-install the radiator again I think.
Old Mar 11, 2007 | 02:53 PM
glennhl's Avatar
glennhl
No need to remove the radiator to just replace a thermostat. Man, that would be one terrible design if that were required.
I didn't drain the radiator, I just removed the old thermostat and lost some coolant. If you work fast you won't lose a lot of coolant. You just have to clean up the mess.
If you want to drain the radiator, there is a petcock on the bottom, not sure which side.
Old Mar 11, 2007 | 02:57 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Yeah I thought about that too! but they told me that.
Old Mar 11, 2007 | 03:30 PM
VET4LES's Avatar
VET4LES
This is the way I would do it also.
Old Mar 11, 2007 | 03:45 PM
MtnC-6's Avatar
MtnC-6
Yeah, that's what I'm looking for which side. May just have to wait until I can get it over the pit so I can see better.
Old Mar 11, 2007 | 07:30 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Put a bucket under the thermostat housing. Loosen the housing bolts and let it drain. Change the stat. Refill and top off. No need to drain the radiator seperately.
Old Mar 11, 2007 | 08:07 PM
NTRBL33's Avatar
NTRBL33
From: The United States of TEXAS www.corvettemotorsportsinc.com
St. Jude Donor '07-'08-'09-'10-'11
drain plug is on right(psngr) side. A little one inch **** to turn
Old Mar 11, 2007 | 10:12 PM
glennhl's Avatar
glennhl
No problem. GM has done some strange things like that in the past!
Old Mar 11, 2007 | 10:37 PM
Mark06's Avatar
Mark06
I was doing the same thing until my hands got slippery with coolant and dropped the F'ing bolt and it rolled to the rear of the car and could not get the second bolt to save my life
Old Mar 11, 2007 | 11:51 PM
haljensen's Avatar
haljensen
The way I did it; Jack up the front to a comfortable working height, place jack stands, locate the radiator drain petcock on the passenger side bottom of the radiator, place a piece of scrap hose on the petcock and drain 2 gallons of coolant out into an old container (I used old 1 gallon cranberry juice bottles). Close the petcock. Remove the thermo housing, replace the thermo housing with the new stat in place, pour in 1/2 gallon of coolant and 1/2 gallon of distilled water, add another 1/2 gallon of coolant to the overflow tank, close the overflow cap and start the motor, let it heat up to to 185° and shut it off, wait an hour and add the last 1/2 gallon of water and you're done. Easy, no coolant on the floor or the motor.
Old Mar 12, 2007 | 12:08 AM
glennhl's Avatar
glennhl
I learned a trick from someone on this forum to get the engine/radiator completely full. Take the small water line off the front of the driver's side head. Take the cap off the radiator overflow reservoir and place your mouth over the opening and blow. I'm just glad nobody had a video camera! You blow until the water comes out the line you removed, fill the reservoir up if it gets low, put the hose back on, and your ready to roll. This works and you don't have to heat up the engine to refill it.
Be careful and DO NOT DRINK THE COOLANT!
Old Mar 12, 2007 | 12:12 AM
DSOMC6's Avatar
DSOMC6
That's sucks as much as when you're changing the oil and you drop the drain plug into the oil pan. I hate when that happens!!
Old Mar 12, 2007 | 08:19 AM
MtnC-6's Avatar
MtnC-6
Thanks for the info
Old Mar 12, 2007 | 05:19 PM
Whiterock1's Avatar
Whiterock1
Why didn't you just reuse the coolant you drained? Or was it time to change it anyway?
Old Mar 12, 2007 | 05:21 PM
Whiterock1's Avatar
Whiterock1
Don't leave it around on the ground, either. It is poisonous to dogs and cats and they are attracted to it because it has a sweet taste.
Old Mar 12, 2007 | 09:18 PM
haljensen's Avatar
haljensen
Coolant is cheap enough that I couldn't justify re-using it, already had over a year use, same with using distilled water, just cheap insurance.
Old Mar 12, 2007 | 09:29 PM
Mark06's Avatar
Mark06
Hell yeah
To Radiator drain plug
