Willl someone that has install a K B boost a pump in an 05, c-6 help me identify the correct wire color and location going to the fuel pump, to connect. Also, where to connect to avoid feed back to the computer. Thanks. What is the best location inside the car to mount the controller?
It will make things easier if you swap in the better racetronics fuel pump power cable. It has provisions for the BAP with connectors already inline. It is 69 bucks on the racetronics web site. It attaches to the alternator with a heavier guage wire and maintains the current to the pump. Don't be intimidated by the picture of the harness. It runs to the pump location and you just connect the connectors. Its 100% plug and play. When I replaced the fuel pump on my C5 it took 30 minutes to run the line and 3 minutes to do the connections.
