Question about extras for Heads and Cam install
Old Mar 17, 2007 | 10:37 PM
vr6aaron's Avatar
vr6aaron
Default Question about extras for Heads and Cam install
Okay I have two questions
1 Do i need to install new wires and plugs? If so exactly which ones? Part numbers etc?
2 What about upgrading the timing chain? If so wich one and where?
I am awaiting my new clutch, and these new puppies are going on. Went with Thunder racing cam and Arf heads. I cant wait.
Any info would be good. Thanks
Old Mar 18, 2007 | 12:09 AM
vr6aaron's Avatar
vr6aaron
Come on, No one?
Old Mar 18, 2007 | 12:29 AM
StarJack's Avatar
StarJack
Colder plugs (like NGK TR55/TR5) and thicker wires are optional. Use advanced search and you'll see some discussion on this.
http://forums.corvetteforum.com/show...ght=plug+wires
I've not read of anyone changing out the timing chain?
After cam/heads (afr 205's?) you should be wearing a bigger smile!
Old Mar 18, 2007 | 09:41 AM
LOS ANGELES PI's Avatar
LOS ANGELES PI
I am told to upgrade to a double roller timing chain for extra strength on high rev deceleration. Have also been told to use a single roller but one with a Torrington (SP ??) bearing to eliminate friction wear.
As to plugs and wires, I dont think so.
But dont take my word on it, I am just starting myself.
Old Mar 18, 2007 | 12:14 PM
glennhl's Avatar
glennhl
I put a cam in my 01Z28 and I did upgrade to a Roll Master double roller timing chain. What a pain, you have to space out the oil pump and then have to re-align the oil pick up tube.
I have read on LS1Tech.com that the LS2 single chain is an excellent unit. A lot of the LS1 guys just use the new LS2 timing chain and avoid the hassle of a double roller.
No need to change out your plugs or wires.
Old Mar 18, 2007 | 12:25 PM
Mike Francoeur's Avatar
Mike Francoeur
Generally we recommend going to a double roller for the added security. The spacing of the pump and making the chain fit isnt that bad. On LS2's you have to grind down the tab where the cam sensor bolts to so it clears the chain. Test fit it without installing the pulley or you'll be sorry. We usually always use a double roller. For the extra $, its well spent. Also, use a NGK TR6. A TR55 is a stock heat range plug. A TR6 is a step colder. For H&C Cars usually we use a 45-48 gap
Old Mar 18, 2007 | 08:47 PM
vr6aaron's Avatar
vr6aaron
Thanks Mike, where is the best place for double roller chain?
To Question about extras for Heads and Cam install
