Handling Question
Old Mar 18, 2007 | 01:30 PM
z06fun's Avatar
z06fun
Default Handling Question
Hi guys,
I just bought a used 05 coupe with 16K miles. While driving at all speeds it seems to want to pull left and/or right when I go over even small ruts in the road. This is my 4th vette (two c5s and a C4) and none of them drove like this. So, is this inherent with the C6 or do I have something wrong. I know the dealer will tell me it is "normal" when I take it in, so I thought I would see if I can get some info first.
thanks
Old Mar 18, 2007 | 01:54 PM
robvuk's Avatar
robvuk
Originally Posted by z06fun
Hi guys,
thanks
How does it track on a straight level road? Otherwise it sounds like you need an alignment. C6 drives even better than a C5 imho. If the dealer tells you it's normal, take it to another dealer
Old Mar 18, 2007 | 03:25 PM
Miaugi's Avatar
Miaugi
Old Mar 18, 2007 | 06:36 PM
z06fun's Avatar
z06fun
Thanks, it seem fine on a perfect road which is why I wasn't sure it was alignment related. A camber issue would have the problem all the time and even a slight toe problem is usually evident in tire feathering. That leaves caster, if it is at the low end of the specs, that might be the problem. I guess a scrub radius differential could also cause the this kind of problem, but there have been no changes of factory wheels or tires. It will be interesting to get the actual alignment specs and try to figure this out. At least I know it isn't normal!
Thanks again.
Old Mar 18, 2007 | 06:41 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Thanks again.
You didn't mention, but how do the inside and outside edges of the front and rear tires look? Any cupping or feathering? HOw's the tread depths look? Presume you checked all this, tho.
Old Mar 18, 2007 | 06:45 PM
Badluck33's Avatar
Badluck33
I'm an owner of a c4, c5 and now c6.
C6 has the best handling by far so do what your told and bring it to another dealer...
To Handling Question
