C6 Z51 break Pads
Old Mar 18, 2007 | 02:52 PM
TaShOo's Avatar
TaShOo
Default C6 Z51 break Pads
What is the best c6 z51 break pads for street racing and dailay use?
what is the diffrant between the z51 and the f55 break pads ?
Do the f55 break pads fit on z51 ?
Old Mar 20, 2007 | 02:41 AM
TaShOo's Avatar
TaShOo
Old Mar 20, 2007 | 08:04 AM
Paul R's Avatar
Paul R
Cruise-In I Veteran
Cruise-In II Veteran
The Z51 and non-Z51 pads on the C6 are a different compound. The Z51 pads are softer, grip and brake better, but dust much more in the process. I switched from the Z51 pads to the stocker pads with no problem just to eliminate the dusting (and possibly the brake squeel I was having also). The pads are the same size and configuration and can be swapped out. The stock pads did reduce dusting considerably, but no change in the noise. I do not notice much difference in braking ability, but then mine is almost purely a daily driver.
By the way, we don't condone street racing around here... I see that you are located in Kuwait, but I bet that they don't like street racing either. Take it to the track.
Old Mar 20, 2007 | 08:23 AM
Miaugi's Avatar
Miaugi
The standard OEM brake pads for the Vette, both the Z51 & non Z51 are quite capable in stopping the car from high speed without much effort, their only short coming would be in repeated hard stops from speed they will wear out faster than a track pad will.
To C6 Z51 break Pads
