Stripped shifter bolt hole
Old Mar 23, 2007 | 11:55 AM
jdenny21's Avatar
jdenny21
Default Stripped shifter bolt hole
I removed my B&M shifter a few days ago and installed a Callaway shifter in an attempt to get rid of the annoying rattle that the B&M had, however it continues to rattle under heavy throttle, guess I need to wait until GM comes out with the "softer" cup piece that snaps onto the bottom of the the shifter. Anyway, I used the bolts callaway provided to secure the shifter to the linkage base on the car and attempted to torque the bolts to 18lbs as stated in Callaway's instructions but one bolt ended up stripping or cross threading, etc and I can not get it tight, I am wondering what I can do to remedy the situation?
Would locktite snug it down enough?
All opinions and recommendations welcome, thanks.
I not sure if the bolts Callaway provided are the wrong size, or different threads, but the did not seem to work well, I used the bolts the came with the B&M after the Callaway bolt stripped the bolt hole on the first bolt I torqued, end up stripping at like 11 lbs. Kinda pissed after spending $280 ($100 more than B&M) and it still rattles and stripped the damned hole.
Does feel better the the B&M though and like the stop bolts, but still annoyed with the whole thing.
Old Mar 23, 2007 | 01:12 PM
goatts's Avatar
goatts
If possible you may need to drill it out and rethread to a larger thread. First try chasing the existing treads with a tread cutting tool and if that holds use the Locktite.
Old Mar 23, 2007 | 01:29 PM
Buffy's Avatar
Buffy
There are thread repair kits made by Locktite and similar vendors that can be used to repair such things. They're essentially epoxys that can be molded in place. A coil insert is another option - you drill the hole out, tap it, then insert a spring-like thing to get it back down to the original size.
P.S. The 18 lb-ft for those bolts is pretty tight. When I changed mine, I chickened out on the 18 lb-ft and used 15 lb-ft with Locktite blue.
Old Mar 23, 2007 | 02:11 PM
jdenny21's Avatar
jdenny21
Default 18 lbs
I agree, 18 lbs is pretty tight, it is BS that Callaway instructs to do this.
Old Mar 23, 2007 | 02:21 PM
ronsc1985's Avatar
ronsc1985
Measure what size and thread pitch the bolt is and buy a Heli-Coil kit. You will need to be able to drill and tap (with the kit tap) the hole. I wouldn't use any of the epoxy thread repair kits as they are really not that strong and strip easily. If you striped the original hole you will have no trouble with an epoxy fix.
The Heli-coil on the other hand is pretty much screw up proof. The inserts are stainless steel and almost impossible to screw up after installation. The kits go for something in the 20 dollar region.
Old Mar 23, 2007 | 03:30 PM
jdenny21's Avatar
jdenny21
How do I measure thread pitch?
Not sure I understand what you wrote:
"wouldn't use any of the epoxy thread repair kits as they are really not that strong and strip easily. If you striped the original hole you will have no trouble with an epoxy fix."
You said don't use the epoxy fill, then you say I would have no problem with it? I did strip the original hole, but not all of the way, the bolt still holds, but it will not torque down tight.
Old Mar 23, 2007 | 05:52 PM
ronsc1985's Avatar
ronsc1985
A. Thread pitch is the threads per inch or millimeter depending on whether the bolt is SAE or metric. Easiest way is usually to try screwing the bolt into a die to find sizing. Some tap and die sets also have a thread gauge which you can use for the same purpose. Either that or go over to the hardware store and find a nut that screws onto the bolt. You will then know the diameter and pitch if someone hasn't screwed up the sorting in the bins (which happens all the time).
B. What I meant was if you stripped the bolt hole in the metal you will have no trouble stripping an epoxy repair if you apply the same torque to the bolt.
I have used both methods to repair striped bolt holes. The epoxy is O.K. if
1. You have a through hole and you can throughly clean the hole with strong solvent before you attempt to repair it. Blind holes are very difficult to clean throughly.
2. You don't plan on removing and inserting the bolt more than once or twice. I never use epoxy unless it's unavoidable as the Heli-coils are infinitely better. Their only downside is you have to be able to get a drill and tap into the hole. In your case this should not be a problem.
Old Mar 23, 2007 | 08:43 PM
2JZFAN's Avatar
2JZFAN
helicoil or timesert?
Old Mar 23, 2007 | 09:48 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Damn. All of these stripped threads, sheared off bolts, http://forums.corvetteforum.com/show....php?t=1657045 and damaged condensors, http://forums.corvetteforum.com/show....php?t=1654275
......come on guys, we're looking bad. We're looking like a bunch of amateur ricers.
To Stripped shifter bolt hole
