Outboards
2 strokes have lots of power for their displacement since every stroke is a power stroke (no wasted exhaust stroke) but use a lot of fuel and burn a lot of oil (no oil reservoir, you add the oil to the gas and burn it up).
Old two stroke motor cycles are a good example, my 500cc Kawasaki outran everything in 1971 regardless of displacement partly because the competition was heavy 4 strokes.
"All new outboards manufactured by Mercury Marine are certified to the
United States Environmental Protection Agency, as conforming to the
requirements of the regulations for the control of air pollution from new
outboard motors."
The newest Mercury motors are about 186 cubic inch motors, make 250HP at WOT, have 2-stage, direct injection and weigh 500 lbs dry.
Yamaha has a new 5.3 V-8 outboard that makes 350 hp and weighs 800lbs
I had one too...but I am now toothless because it vibrated them all out along with most of the bolts in the bike...but it was GREAT fun!!
Mercury had a 300 HP OB years ago, but was slower than the 200 because it weighed so much. Not just the extra weight per se, but it upsets the Bass Boats attitude and is less efficient in the water.
90mph on the water in a 20+' Bass Boat=165+mph in the C6, in terms of sphincter clinching.
You have to remember that those published weights include midsections, lower units, cowlings, all of the electronics, etc. All of that equiptment weighs a significant amount, I would bet that the block with pistons and all only weighs about 40-50% of the published weight.
The 300 hp, Mercury Optimax XS 3.2L 6 cylinder 2-stroke direct injection block with pistons, crank, etc supposedly weighs around 250lbs.
The 300 hp Suzuki 4.0L 6 cylinder 4-stroke weighs 600 lbs fully rigged, so around 300lbs in automotive configuration.
Today's direct injection 2 strokes are also just as fuel efficient if not more so than 4 strokes, atleast in boat engines. Check out some of the tests on the new outboards, such as the 225 shoot-out in Bass and Walleye magazine a few months back, the 2 strokes were faster and more fuel efficient. They do however, burn oil.
How do you think that Optimax block would perform on the back on a dune buggy or race car? If a heavy duty radiator setup works on those buggies that run in those endurance races in the desert then I'm sure it would cool one of those things.
Last edited by sbennett5; Mar 25, 2007 at 11:31 PM. Reason: added info on fuel economy
You can't compare a 2-stroke to a 4-stroke. If you are, that's a big part of the discrepancy.
90mph on the water in a 20+' Bass Boat=165+mph in the C6, in terms of sphincter clinching.[/QUOTE]
I know this all too well. Rocking side to side with 3 inches of the boat in the water at 90+++ is a little scary. I'd rather do 165 in the vette then 90 in the boat.
By the way you guys should go to Evinrude's site and look at the new E-Tec. 2 strokes have come a LONG way.
