Mods - Dyno results
Old Mar 24, 2007 | 07:48 PM
DAlbertson's Avatar
DAlbertson
Default Mods - Dyno results
I have a 07 VERT MN6, with ~800miles.
Mods:
LG Pro LT headers with high flow cats
Corsa Sports
Dyno results of 366 rwhp and 368.5 rwtq after a tune. I don't have before sheet but was advised by tuner that hp increase was 32 from stock.
Is this a bit low or in expected range? Will it go up some after I put more miles on? Just curious, I love current performance and sound so HP numbers are not too important to me.
Just for sake of 'mod completeness', I may throw on a CAI and dyno again in a few months. Will a CAI add any significant amount of noise? Don't want much more, I am at a good level right now. The LGs and corsa sports RIP!
-Dave
Old Mar 24, 2007 | 08:02 PM
C6Brian's Avatar
C6Brian
My 900 mile old 07 coupe M6 (BONE STOCK) with only a custom tune dynoed at almost those SAME exact numbers you got on a dyno jet. My numbers were SAE corrected and I am at sea level(no elevation). Yours seem low for sure if you have headers. My tuner said I should be pushing 400 with header/catback and a retune. Better get a second opinion.
Old Mar 24, 2007 | 08:23 PM
glennhl's Avatar
glennhl
Check to see if you have the 799 heads. Your numbers seem about 10 hp low.
Old Mar 24, 2007 | 09:55 PM
DAlbertson's Avatar
DAlbertson
thanks for reply. I checked and have the 243 heads.
Old Mar 24, 2007 | 09:59 PM
cbrf4i1's Avatar
cbrf4i1
the 799 are the hot heads over 243 now since it is semi CNC.
cai will not increase your exhaust noise.
Old Mar 24, 2007 | 10:08 PM
C6Brian's Avatar
C6Brian
Maybe he was wondering about more intake noise, and I did experience that with my cobra when I installed a CAI over the stock air box. You could hear the sucking and more engine noise, but it was welcomed.
Old Mar 24, 2007 | 10:10 PM
glennhl's Avatar
glennhl
Where can I pick up some of these hot heads? I think Vidal has some.
Old Mar 24, 2007 | 10:13 PM
cbrf4i1's Avatar
cbrf4i1
yes, he has 2 of them, one for you and one for me...now we will have a hybred and pull to one side like the front wheel drives...sorry for the hi jack.
Old Mar 24, 2007 | 11:56 PM
Slow Vette's Avatar
Slow Vette
which heads do you have? 243 or 799?
Old Mar 24, 2007 | 11:57 PM
C6Brian's Avatar
C6Brian
Old Mar 25, 2007 | 12:03 AM
Evilways's Avatar
Evilways
32 RWHP is a good gain from your mods. The car was a little low, stock,it seems for a M6. Usually the A6 is the bottom feeder when dyno'd stock. Mine was 337 bone stock. You may dyno a lttle higher after you put more miles on the car. For some reason, a 5 or so RWHP increase is often seen after a few thousand miles.
Old Mar 25, 2007 | 12:51 AM
Slow Vette's Avatar
Slow Vette
YES!! you may dyno higher after more miles, every car is different.
Old Mar 25, 2007 | 01:54 PM
aTX427
Guest
Posts: n/a
It sounds like a solid gain. All dyno's are different. Yet another dyno and see what it pulls
Old Mar 25, 2007 | 06:00 PM
vett2go's Avatar
vett2go
Yeah the 799 head are the limited production versions.
To Mods - Dyno results
