down shifting
Old Mar 28, 2007 | 12:00 PM
launchp's Avatar
launchp
Default double clutching
I understand the bliping the throttle...but...What do you mean by double-clutching? Just pumping the clutch twice prior to shifting?
Old Mar 28, 2007 | 04:07 PM
c6speedjon's Avatar
c6speedjon
Originally Posted by opus1111
I downshift like a madman ALL the time. In fact, I really don't use my brakes much except to scrub speed from a speed run, pulling up to a stop sign, or aggressively diving into corners. As a former motorcycler, I'm very good at blipping throttle to match revs exactly so when the clutch comes out, there's no shock at all. This is why I get so much enjoyment out of the stick shift vs. auto/paddles: this takes practice and tough to pull off. Heel-toe downshifting is this technique taken to the next level to add braking into the throttle blipped downshift. Very fun to practice and do well. Adds much enjoyment to driving! Also, with an aggressive exhaust, the engine music is INTOXICATING.
REV MATCHING is so fun! Do it all the time!
Old Mar 28, 2007 | 04:49 PM
NO1Z51's Avatar
NO1Z51
Oh yeah I try my best not to jerk but man does it feel awesome when all that torque just throws you back. Im gonna start practicing on that blipping method. Thanks for all the different inputs..you guys know your stuff.
Old Mar 28, 2007 | 04:56 PM
vette-oholic's Avatar
vette-oholic
I thought I read somewhere that the A6 has auto blip rev matching just like some of the higher end cars?
Originally Posted by DSOMC6
Not to highjack this thread, but,this leads me to a question:
On an A6 when downshifting, at times I tend to blip the throttle in between downshift shifts, as there is a very slight hesitation. I have often wondered if this is hard on the tranny???
Old Mar 28, 2007 | 06:11 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Old Mar 28, 2007 | 09:57 PM
JD21029's Avatar
JD21029
Double clutching is when you clutch to put the car into nuetral, and then clutch again to put the car into gear (depress clutch, shift to N, release clutch, depress clutch, shift into gear, release clutch). In my old truck driving days I used to double clutch every shift, but I've never done it in a car with a functioning clutch. Its used to syncro the gears. Why would you do it in a Vette?
Old Mar 28, 2007 | 10:09 PM
C6 MoneyPit's Avatar
C6 MoneyPit
St. Jude Donor '06-'07-'10, '15. '22-'23
From a purely non-practical standpoint, I downshift my A6 all the time when slowing down just to hear the exhaust burble!
Old Apr 20, 2007 | 09:02 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Downshifting doesn't hurt the engine but it does wear out the clutch.
Brake pads are way cheaper than a clutch replacement. Use your brakes!
Tom
Old Apr 20, 2007 | 09:17 PM
Gary Jordahl's Avatar
Gary Jordahl
Having 4 and 5 speeds all my life I have noticed the close ratio M6 on the C6 kind of throws me off a bit on the downshifting. For example downshift to 3rd and 2nd get more revs than I'm used to. Not a problem, just a matter of getting used to it. On the M6, I really don't see a need for a downshift in any gear lower than 3rd. In 2nd you're almost stopped anyway, unless your on the track or something........
Old May 14, 2007 | 07:03 PM
salto99's Avatar
salto99
Three words... Heel and toe
The gas peddal is not an on-off switch like all the SUVidiots and automatic trans. lemmings think it is. It is a reostat of sorts.
Learn how to rev match and driving will be that much more enjoyable.
http://www.edmunds.com/ownership/how...2/article.html
Old May 14, 2007 | 07:46 PM
Shark Racer's Avatar
Shark Racer
Double Clutching
This is what I do.
6-4 downshift as an example. Cruising along at roughly 65 mph - ~1500 rpm.
Put the clutch in.
Shift from 6th to Neutral.
Pull the clutch out.
REV the engine to 3000 rpm.
Push the clutch in.
Put the car in 4th.
Single Clutch Downshift
Same scenario as above.
Push the clutch in.
Put the car in neutral.
Rev the engine to 3000 rpm.
Put the car in 4th gear.
Heel-Toe Downshifting
Heel-toe is a modifier to any of the above techniques - it involves braking while doing one of the above.
While braking, rev the engine for the appropriate speed for the downshift. Use your brain to figure this out. If you have a big foot, you may get away with tapping the gas with the right side of your foot while braking with the left. If you have a small foot, you may have to actually hit the gas pedal with your heel while you apply the brakes with your toe. It's not an easy technique to learn, especially on the street.
Enjoy. Loud exhaust makes the above techniques much more fun.
Old May 14, 2007 | 08:08 PM
VET4LES's Avatar
VET4LES
Originally Posted by Whiterock1
If God didn't want you to downshift, he would never have made manual trannies...
I do it all the time because it's a fun way to drive and use the MZ6.
Old May 15, 2007 | 08:17 AM
  #33
AutoCutter's Avatar
AutoCutter
If you own a manual transmission then you can learn the fine art of Heel and Toe downshifting. For me, the C6 does not allow for true "Heeling" of the gas pedal. Rather I roll the side of the foot over to the gas pedal. Technically, there is no "toe" involved, rather the ball of the foot is hard on the brake.
The purpose of Heel and Toe is to provide additional braking via the engine's compression and to put the transmission in to a more useful gear to exit the corner during racing conditions. It has no other purpose in day to day driving other than to reinforce your Heel and Toe skill set. It does cause additional wear on the transmission and clutch; how much depends on your skill set and gear choices.
Use your brakes if you never going to race or travel the high speed curvies like the Tail of the Dragon. However, if you just want that wonderful "Wambaa, Wambaa" sound like Sterling Moss or Phil Hill produced diving deep in to a curve(or offramp ) then Heel and Toe shifting is what you need to learn.
