WCC lowering bolts: How much does....
Old Mar 27, 2007 | 03:50 PM
SPANKY LS1's Avatar
SPANKY LS1
Default WCC lowering bolts: How much does....
WCC lowering bolts: How much does "X" turns raise or lower the car?
1/4 turn = ___"
1/2 turn = ___"
3/4 turn = ___"
1 turn = ___"
Thanks, Shawn
Old Mar 27, 2007 | 04:20 PM
Buffy's Avatar
Buffy
The stock bolts are about 2mm per turn; these would have to be the same if they fit the same threads. So:
1/4 turn = 0.5mm = 0.020 inch
1/2 turn = 1mm = 0.039 inch
3/4 turn = 1.5mm = 0.059 inch
1 turn = 2mm = 0.079 inch
Old Mar 30, 2007 | 09:50 PM
SPANKY LS1's Avatar
SPANKY LS1
So if I turn the bolt two turns, it will only raise/lower the car .158"? To lower/raise it 1" I would have to turn them 12.65 turns? Doesn't that sound like a lot?
Not doubting, just asking.
Thanks, Shawn
To WCC lowering bolts: How much does....
