skip shifter install
Old Mar 29, 2007 | 05:18 AM
nicosuave's Avatar
nicosuave
Default skip shifter install
I just ordered a skip shift eliminator. Is this something I can install myself? How is it done? Thanks.
Old Mar 29, 2007 | 05:36 AM
timd38's Avatar
timd38
It will take you longer to jack the car up than to install it. My wife could do it......
Old Mar 29, 2007 | 10:30 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
it takes more work to get under the car than it does to install it.
Old Mar 29, 2007 | 11:22 AM
crabman's Avatar
crabman
If your not overweight you can drive one side up on the curb, throw a blanket down on the ground and slide under the rear end. Its the only tagged connection. White/black lettering, says something like SKPSHFT. Been more than two years so I dont recall exactly. Bring a needle nose so you can pull your zips tight and trim them. 5 minutes from start to finish, no jacking, dont let the ol lady see one of her good blankets on the ground.
Old Mar 29, 2007 | 12:26 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Its a very easy install once you figure out where the connection is.
As everyone states it takes longer to jack the car up securly then to do the install.
As a suggestion if you dont have a set of ramps I would invest in some rhino ramps (and jack stands) which will make working under the car much safer.
To skip shifter install
