Passenger door unlock and window controls
Old Mar 31, 2007 | 07:43 AM
Jackj42's Avatar
Jackj42
Default Passenger door unlock and window controls
My C6 passenger door unlock, open, and window switch are not working on the passenger side. The passenger door will unlock with the fob or the driver's side unlock switch, and can be opened from the outside, and the window can be operated from the driver switch, also, but everything on the inside of the passenger door is dead.
I recently had some speakers installed in the front doors and probably hadn't tried the passenger side controls since. I that the likely cause or is there a switch somewhere I am missing that disables the passenger door controls?
Thanks in advance.
Jack
Old Mar 31, 2007 | 09:19 AM
calemasters's Avatar
calemasters
that the likely cause: YES
or is there a switch somewhere I am missing that disables the passenger door controls: NO
