Front Tire Wear
Old Apr 3, 2007 | 11:36 PM
Driver_WT's Avatar
Driver_WT
St. Jude Donor '07
Default Front Tire Wear
Dealer says both front tires are worn on the inside, my 05 C6, to the point where they need to be replaced. Still lots of tread across the tire except for the inside. Technician says that an alignment is not necessary, this is just how C6 front tires wear. Have about 15k miles on GY EMT (non Supercar) tires. Still have about 8/32's on the remainder of the tread.
I am thinking that the alignment is off. Any thoughts?
Thanks.
Old Apr 4, 2007 | 12:01 AM
Vetteinplano's Avatar
Vetteinplano
Thanks.
I had the exact thing: Both wore on the inside edge.
Replaced the two front tires at 18K and had he realigned at a performance shop: He gave is just a little more positive camber (made the tires "stand" up just a little straighter.
The car "feels" just a little "looser", and steers a little easier at low speeds.
At 26K, the tires still look new.
Old Apr 4, 2007 | 07:39 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Thanks.
Any "technician" that says an alignment isn't necessary for those conditions doesn't know crap about suspension geometry and adjustments. Take the car to someone who knows.
Old Apr 4, 2007 | 07:55 AM
foliva's Avatar
foliva
The wear pattern you depict is what I would expect from a performance oriented alignment. Usually some negative camber is dialed in for better allow better cornering capability.
This, in conjunction with appropriate toe settings, can really make a difference in the handling of your car. However, the price you pay is increased wear as shown/described.
Again, as you state, dialing in less negative camber will allow the tires to wear more evenly at the cost of somewhat reduced cornering performance. It's all a tradeoff.
Fred O
Old Apr 4, 2007 | 06:04 PM
Vetteinplano
My 05 had the factory alignment that caused this wear. I changed the alignment slightly and now it's wearing evenly.
Old Apr 4, 2007 | 07:27 PM
calemasters's Avatar
calemasters
Mine wore evenly across the width of the tread.
Old Apr 4, 2007 | 10:41 PM
z06Bigbird's Avatar
z06Bigbird
Totally agree.
Ed
To Front Tire Wear
