C6 Varam Intake
Old Apr 9, 2007 | 07:35 PM
ZO6 Fan's Avatar
ZO6 Fan
Default C6 Varam Intake
Installed unit today w/ Throttle Body Spacer-"Check Engine " icon is flashing! WHY?Thanks to all
Old Apr 9, 2007 | 07:44 PM
Miaugi's Avatar
Miaugi
Did you remove/change your shroud? If so, there is a sensor on the drivers side of the radiator, could it have been not reconnected?
Old Apr 9, 2007 | 07:57 PM
cbrf4i1's Avatar
cbrf4i1
what is the code?
Old Apr 9, 2007 | 08:04 PM
VET4LES's Avatar
VET4LES
I would check for a leak.
Old Apr 10, 2007 | 08:06 AM
BlackZ51Vett's Avatar
BlackZ51Vett
Old Apr 10, 2007 | 08:10 AM
Ultimate CC's Avatar
Ultimate CC
wats the code?
Old Apr 10, 2007 | 08:53 AM
AFVETTE's Avatar
AFVETTE
Do you have a Code Reader??? Anyone attempting "mods" on a C6 really needs one. This is the I and many buddies use - http://www.diydiagnostics.com/ make sure which ever code reader you buy supports CANBUS (Controller Area Network). Best $65 you can spend especially if it saves you a trip to the dealer.
Good luck these cars are so finicky especially when messing around with the air intake and AFR's.
Tom
Old Apr 11, 2007 | 11:28 AM
ZO6 Fan's Avatar
ZO6 Fan
Originally Posted by cbrf4i1
what is the code?
Can I use the Diablo Sport Predator I just purchased? It has a feature for Diagnostics. Thanks
Old Apr 11, 2007 | 02:55 PM
cbrf4i1's Avatar
cbrf4i1
yes, or you local auto store and pull the codes for you for free too.
To C6 Varam Intake
