O2 Sensor wiring
Old Apr 9, 2007 | 11:06 PM
C5nNC's Avatar
C5nNC
Default O2 Sensor wiring
Put LT kooks on. Got CEL for O2 code. I tried switching sensor wires and need to make sure I have correct wiring. When looking up at car the sensor coming out of the cats area points to the inside. Does the wiring from that sensor then go to the opposite side upper sensor? or does it curve back and plug into the same side as the bottom sensor?
Old Apr 9, 2007 | 11:18 PM
GMautotech's Avatar
GMautotech
First off what is the code? That will tell us what sensor(s) is the problem.
Old Apr 9, 2007 | 11:35 PM
C5nNC's Avatar
C5nNC
Not sure, just know it's emissions code
Old Apr 10, 2007 | 06:07 AM
daveven's Avatar
daveven
i curved the wire back and pluged the right and left banks into the same side harness. never had codes. are your headers coated. if they are not the cats may not get hot enough and throw a code.
To O2 Sensor wiring
