Dyno Tune ?? help
I keep seeing threads talking about (dyno tune). What exactly is this and what does it do ? I have tried doing a search but can't find the exact answer. Can someone please explain this or direct me to a thread that explains it ? Thanks in advance..
A dyno tune is when a tuner taps into the engines computer and starts to alter the settings programmed into the car from the factory. Basically they will optimize the engines air/fuel ratio, spark, torque management, and a whole bunch of other things that will make your head spin. Since GM, or any car manufacturer has to follow certain guidelines and restrictions, as well as keeping the car safe and driveable under all conditions, they "tune" the cars quite conservatively. So a good tuner will be able to go into the car's computer and get more power and a little better driveability for those of us who want a slightly more aggressive performance vehicle.
Since a dyno tune will usually run you anywhere from $200-$500 it's best to wait until after you have done some engine modifications, ie; CAI, intake, headers, gears, etc. before you get a dyno tune so you don't have to pay to have it done twice.
I know I went into a little more detail than you probably needed. And I'm not trying to be condescending. I'm just assuming you know nothing so I can base my answer on how much info you may need. Better to have too much, than not enough. Good luck and if you need anymore help, we're here.
As far as warranty. Well it depends on the dealer you take it to. Although I have yet to hear anyone say they had a warranty denied because of a tune. But your tuner can save a copy of your stock tune and reinstall it if you have to bring the car in for warranty work. That is something you'll have to work out with your tuner. However your warranty for the non-engine related parts will not be affected. Windows, radio, seats, etc. Where are you located(state)?
The reason I asked what trans you had is because most people seem to beleive the torque management is more intrusive in the A6. So a tune would definately help with that. Not to mention alot of good tuners are changing the shift points and making the A6s much more fun to drive. The M6 will benefit from a tune as well though. Depending on where you live, there are a lot of good tuners out there. Best of luck.
