LS6 to LS2 intake
Old Apr 11, 2007 | 10:29 PM
stinky's Avatar
stinky
Default LS6 to LS2 intake
Once a LS6 intake is modified to accept 90mm tb, will the LS2 injectors, fuel rail, etc. mount to the LS6 w/o issues?
Old Apr 11, 2007 | 10:33 PM
Cory@LS2PortWorks's Avatar
Cory@LS2PortWorks
St. Jude Donor '09
The fuel rails are different for sure. Also the injector o-ring is different. The LS2 injector lower o-rings won't fit the LS6. Get o-rings from a LS1/LS6. In fact... just use injectors from one too. Tune accordingly, of course.
You would do better to buy a used LS1/LS6 fuel rail and use it. They are cheap anyway... ~$50 if you look around.
