Service Charging System?
Old Apr 12, 2007 | 08:16 PM
Mad*Max's Avatar
Mad*Max
Default Service Charging System?
There was a ringing sound coming from the engine when I came back from work today. Went for a spin in the evening and 10 minutes later got a "Service Charging System" message but it went away without me resetting it. Now there is no ringing sound coming from the engine. The alternator's voltage looks good. Any thoughts before I let the dealer tear my car apart? Only have 1300 miles on it and 3 months old.
Old Apr 12, 2007 | 09:12 PM
outnumbered's Avatar
outnumbered
Check your horn. Mine blew a fuse and got the same message and voltage was fine.
Old Apr 13, 2007 | 11:04 AM
Jack C's Avatar
Jack C
If You Hit The Rev Limiter It Can Throw That Code Also Can Damage Alternator From Fan Blade (plastic) Flexing And Hitting Wires.
Old Apr 13, 2007 | 06:20 PM
Mad*Max's Avatar
Mad*Max
Please explain "Rev Limiter" - sorry but I am not sure what you mean - I guess I am not technically savvy?
Old Apr 13, 2007 | 08:15 PM
VET4LES's Avatar
VET4LES
When the RPM's reach around 6700 the fuel is temporarily shut off. It is a good idea to shift before that happens. I have not heard of any damage done by doing it but it's best to shift first.
Old Apr 14, 2007 | 07:34 AM
Jack C's Avatar
Jack C
Default Mad*max
I'm No Tech But I Think The Fan Inside The Alternator Flexes When There Is A Sudden Change In Rpm's. Mec At Dealer Told Me There Was A Gm Notice About This.
Old Apr 14, 2007 | 08:01 AM
Mad*Max's Avatar
Mad*Max
But I like to rev up my engine, that too suddenly - that's what I bought the car for. If there is a GM Notice about this, did they come up with a fix for it?
Old Apr 18, 2007 | 05:50 PM
Mad*Max's Avatar
Mad*Max
For those who were anxiously awaiting the outcome of this thread - I ended up getting a new alternator today
Old Apr 18, 2007 | 06:01 PM
HAVAN123's Avatar
HAVAN123
I had the same problem and almost went with a new alternator when , at the last moment, my tuner told me tha he heard of a GM bulletin about a falty harmonic balancer that starts to vibrate exessively especially after a cam swap. Had it replaced under warranty and the problem has been solved.
To Service Charging System?
