I just took our Vette into the shop for the doors rattling. First time thru they said they replaced a clip in the door and this last time they ordered a whole new door panel. If you push on the panels does the vibration go away? you might have a loose clip or maybe something else is loose behind them.
easy fix. the vibrations comes from the area where the plastic of the door panel near the seat belt area meets the plastic door. ijust folded some of my busness cards in half an inserted them between the 2 panels and no more vibrations. did the same thing on my last car
That's what I did....however I tore the card off and left a small piece there so it didn't look so obvious.
