help, diff fluid change
Old Apr 16, 2007 | 03:37 PM
IC6's Avatar
IC6
Default help, diff fluid change
my drain plug on the diff was easy to break loose, but the fill plug is insanely tight, can't break it.. am i doing something wrong? is it reverse thread? i don't want to strip the head, and am afraid to if i keep wailing away on it
no need to worry too much, i didn't drain it yet, but i'd like to get it done since i have the car up...
Old Apr 16, 2007 | 04:20 PM
6 speed Sid's Avatar
6 speed Sid
Should not be reverse thread, as I recall. On both the C5 & C6, the tranny plugs were very tight as they had a red thread locker on them. They will break loose with a snap. Get a long breaker bar or pipe extension. Worked for me.
Old Apr 16, 2007 | 04:59 PM
Viprklr's Avatar
Viprklr
Anytime I have changed fluids on previous cars I always attempt to loosen the fill plug before the drain plug. That way you avoid the trouble of leaving the car inoperable. Good for you for not draining it yet. Hopefully this saves someone else trouble in the future.
Get an extension and it should come off.
Matt
Old Apr 16, 2007 | 05:55 PM
REVAK's Avatar
REVAK
Mine was also very tight. If I recall it is a metric hex recessed plug. I had to use a long 3/8 drive breaker bar and apply a heavy, sharp, snap to break it. It is normal right hand threads, so as you face the fill plug, counter clockwise to loosen/remove. Good luck.
Old Apr 17, 2007 | 04:21 PM
IC6's Avatar
IC6
thanks for the corfirmation on the thread direction ended up getting it w/ a fairly long breaker bar and some clever repositioning to get some good force on it..
damn, that badd larry didn't want to come off...
on a side note... w/ the smaller flowmaster cans under there, i was able to just tip and squeeze the royal purple bottle in the hole and not worry about fumbling w/ a small fluid pump.
Old Apr 17, 2007 | 05:09 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Default Valuable information
I changed the differential fluid BEFORE putting on the B&B Rt 66, so I had to use the pump-it-in method.
All who are looking at changing the fluid: The fill plug is REALLY TIGHT, and I needed a long pipe on the 1/2 inch breaker bar to get it loose.
And it does take a 10 mm hex drive. I mistakenly thought it was 3/8 inch SAE hex, and bunged up the plug pretty badly. That gave Fichtner the opportunity to sell me a shiny new replacement. Use the 10 mm hex and save your pennies.
To help, diff fluid change
