Check Engine Light in Newark, DE
Old Apr 18, 2007 | 08:15 AM
tjsolimeo's Avatar
tjsolimeo
Default Check Engine Light in Newark, DE
The "Check Engine" light came on with only 2,800 miles on my '07 C6 coupe. Can anyone recommend a dealer/service department in the area? Should I wait a few days and see if the light resets? Should I get/borrow a code reader at a Parts Plus and see what the problem is? I've checked the gas cap and it seems seated tightly.
Old Apr 18, 2007 | 11:17 AM
cbrf4i1's Avatar
cbrf4i1
your local auto parts store like autozone or checkers will pull the codes for you for free without any waiting.
Old Apr 18, 2007 | 11:43 AM
DJackman's Avatar
DJackman
You can either unplug the battery for ten minutes to reset the Check Engine Light and never know what the problem is, or go to Autozone and borrow/buy their CAN OBD II scanner to see what it is and also reset it, or take it to good old Mr. Goodwrench.
Old Apr 18, 2007 | 02:47 PM
tjsolimeo's Avatar
tjsolimeo
Thanks guys. I ordered a $65 code reader, which should be here in a day or two. At least I can turn off the light if it is a code. If it reoccurs, I'll at least know what the dealer is supposed to be working on.
To Check Engine Light in Newark, DE
