Had to pull fuses to correct....why?
Apr 23, 2007 | 10:10 AM
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
After pushing my start button, rapid clicking (normal) the clicking would not turn off,
car did not start, no dic or code.
Popped out a few fuses under hood then reinserted fuses and it corrected and started. Now it's fine.
Can anyone explain?
Apr 23, 2007 | 05:30 PM
This disconnected power to the ECM and/or BCM which allowed the ECM or BCM to "reset", depending on which fuse(s) you removed.
Apr 23, 2007 | 08:28 PM
Pulling the right fuse is like re-booting your computer.
Apr 23, 2007 | 09:25 PM
Quote:
Originally Posted by
VET4LES
I get that, why did the rapid fire start and not stop
what caused the issue to start with ?
ty
Apr 24, 2007 | 02:41 AM
Apr 24, 2007 | 01:51 PM
calemasters
It is an anomaly.
That's what an Engineer calls a failure that they are too lazy to explain.
Apr 24, 2007 | 05:56 PM
glennhl
Exactly.
Apr 24, 2007 | 06:17 PM
They use Windows XP.
Apr 24, 2007 | 08:22 PM
glennhl
Just remember, you can tell an engineer, but you can't tell them much.
