CAT Delete pipe
Old Apr 27, 2007 | 06:47 AM
mo-shy's Avatar
mo-shy
Default CAT Delete pipe
i have Dynatech Supermaax headers -Hi flow catalytic converters and x pipe.
i heard there is CAT delete pipe or race pipe that well cansel the catalytic. cause i heard if i delete the CAT i have more flow more sound more hp.
where i can get this pipe?
Old Apr 27, 2007 | 10:18 AM
cbrf4i1's Avatar
cbrf4i1
i am sure dynatech makes a off road pipe for the headers, trying contacting them. just about all the lt headers manufacture has this option.
Old Apr 27, 2007 | 10:55 AM
mo-shy's Avatar
mo-shy
Do you think i have check engine light if i use off road pipe ?
is it true cat less make the sound loudest?
Old Apr 27, 2007 | 10:58 AM
06.Z51.MontRed.Vert's Avatar
06.Z51.MontRed.Vert
From: Eastern PA:ECS Paxton Novi 1500(676rwhp,585tq on stock engine),LG headers, 410's, Corsa Sports, ECS Alky Kit
St. Jude Donor '08-'09
In my neck of the woods they are sold for $25,000 (actually that is what the fine costs if you get caught without the cats)...
You aren't going to lose much sound or power if you go with high flow cats, might want to keep that in mind if you have gestapo emmisions like we have.
Old Apr 27, 2007 | 10:59 AM
dbradley's Avatar
dbradley
Actually he's already there. You aren't even allowed to "move" the cats in the Federal regulation.........
Old Apr 27, 2007 | 04:12 PM
cbrf4i1's Avatar
cbrf4i1
yes, cel will be on unless you had a tune already and it has turn off the rear o2's. see my sig.
yes, catless will make your exhaust a little louder then what you have and gain some hp/tq too. you do have to figure out how to pass emission when that time does comes.
Old Apr 27, 2007 | 08:02 PM
huckleberrydude's Avatar
huckleberrydude
where I am at, they do a visual inspection only. I took the stock cats and cut them in half at the factory weld. We cut a section of 2.5" pipe that fit perfectly through them and welded them in. Then we rewelded the factory welds on the cat. The result is a complete factory look without cats. those censors can be tuned out by your tuner although they can retain the factory location. the exhaust got a lot louder.
Old Apr 27, 2007 | 10:17 PM
saplumr's Avatar
saplumr
I've got the KOOKS offroad x-pipe and the odor is atrocious. I would go back to high flow cats but my tuner is 400 miles away.
To CAT Delete pipe
