Which Oil and how much?
Old Apr 27, 2007 | 11:13 AM
fright88's Avatar
fright88
Default Which Oil and how much?
Ok so I am going to stop and get some oil for an oil change on my way home. Planning on mobil 1 can someone please tell me which weight and how many quarts I need? Owners manual is at home with the vette. Thanks
Old Apr 27, 2007 | 01:41 PM
vcheng's Avatar
vcheng
Mobil 1 full synthetic 5w30, meeting GM4718m specification.
I would suggest picking up 6 quarts.
Old Apr 27, 2007 | 01:56 PM
fright88's Avatar
fright88
Thank you.
BTW anyone have a preference for filter?
I have found STP and Fram locally
Duralast K&N and Motorcraft can be had if I order it.
Thanks for any advice.
Old Apr 27, 2007 | 02:05 PM
Michrider's Avatar
Michrider
ACDelco PF46 Chevy dealers have them, as well as most better auto parts stores.
5.5 qts Mobil1 5w30 silver cap (regular Mobil1 not the extended performance)
6 qts if it has the Z51 perf package
Old Apr 27, 2007 | 02:47 PM
vettl83's Avatar
vettl83
I have had good luck with the Mobil 1 filter in all three Vettes, just a little spendy at about 12.00 a copy.
Old Apr 27, 2007 | 03:00 PM
CodyC6's Avatar
CodyC6
Remember the Delco filter is PF48 for the 2007s.
Old Apr 27, 2007 | 03:02 PM
Michrider's Avatar
Michrider
His profile shows it as an 06, which will be the PF46. Your right about the 07s, all 07s went to PF48.
Old Apr 27, 2007 | 04:38 PM
986_C6's Avatar
986_C6
I personally have used Fram for the past 20 years...the Best!
Old Apr 27, 2007 | 05:20 PM
aTX427
Guest
Posts: n/a
Actually, Fram is one of the worst on the market. They are made of cardboard and have the tendancy to collapse. I use Mobile 1 - they are high middle of the road, but easily available.
http://www.oilfilterstudy.com/
Old Apr 28, 2007 | 10:21 PM
turmat's Avatar
turmat
Old Apr 29, 2007 | 12:36 AM
Rob Willis's Avatar
Rob Willis
Anyone know the K&N # for the 2007s?
Old Apr 29, 2007 | 05:35 AM
painexpert's Avatar
painexpert
K&N filter # HP 10-17
Old Apr 29, 2007 | 07:39 PM
VET4LES's Avatar
VET4LES
Stay away from Fram.
Old Apr 29, 2007 | 08:14 PM
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
My local chevy dealer installs 10-30 as the temp's in Texas are higher than most of the country, so I put in the 10-30. Because of the little thicker oil my oil life went to 71 percent upon start up and now after 1000 miles reads 58 percent left.
I will be going back to 5-30 next week.
Total price out the door at Advance auto parts with filter was $25.02 and it takes me about 20 min. total time.
Old Apr 29, 2007 | 11:58 PM
GotVett?'s Avatar
GotVett?
What's the difference between the reg. Mobile 1 (silver) and the extended Mobile 1 (gold)? I saw that at Walmart and Pep Boys today and didn't know which to get. They also had a Mobile 1 filter in the correct size.
Old Apr 30, 2007 | 10:17 AM
fright88's Avatar
fright88
Thanks for all the help. Used the AC Delco filter. And Mobil 1 5 w 30
Old Apr 30, 2007 | 02:31 PM
NORTY's Avatar
NORTY
That's the one to use!
Old Apr 30, 2007 | 02:40 PM
fright88's Avatar
fright88
That is what the dealerships use how do you figgure?
To Which Oil and how much?
