160 replacement
Old Apr 29, 2007 | 11:32 PM
LMB 4 ME's Avatar
LMB 4 ME
From: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
Default 160 replacement
I just purchased a 160 degree thermostat, how hard is it to replace and are there any secrets other then using distilled water only?
Old Apr 30, 2007 | 12:08 AM
cbrf4i1's Avatar
cbrf4i1
very easy to do, drain about 1.9 gal of coolant (some don't even do this), then remove the 2 bolts on the stat housing, swap out the stock stat for your 160. tighten the 2 bolts that you just took out, then added dex cool / distill water to whatever water to coolant ratio that you desire.
Old Apr 30, 2007 | 12:52 AM
LMB 4 ME's Avatar
LMB 4 ME
Thanks Man!
To 160 replacement
