Cross drilled rotors
Old May 2, 2007 | 03:21 PM
ahawkins's Avatar
ahawkins
1st Gear
Default Cross drilled rotors
Has anyone tried these on there vett?
http://www.brakeworld.com/catalog.asp?page_id=item&invid=38549&loc =front&desc=C6%20[NON%20Z51%20PACKAGE]
they look sweet
thanks,
aaron
Old May 2, 2007 | 04:26 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
$275 a piece? A little pricey. Is that for the standard or Z51 size? For a little more, you can get a quality two piece rotor and save some weight.
Old May 2, 2007 | 05:24 PM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
You can buy a full set of Baer Eradispeeds for 999.00 or less. They are two piece, standard front with 14" rear rotor(looks cool) drilled, slotted, and zinc coated. Also have a limited lifetime replacement warranty if they warp. By adding the larger rear rotor you give up any weigh savings( this combo is the exact weight of the stock system according to Bear) but they sure look cool.
Old May 2, 2007 | 06:53 PM
blacktop373737's Avatar
blacktop373737
Hi silverspeed, I put these on my base C6 and I thought they were the best mod I have done. The rear wheels had a special bracket for the calipers. I am thinking of trading for a Z51. Will the rotors work with new car. Does the Z51 not require the rear rotor brackets? thanks,blacktop
Old May 2, 2007 | 08:17 PM
martinblank's Avatar
martinblank
Old May 2, 2007 | 10:48 PM
Silverspeed
To be quite honest......I don't know for sure. I have the base suspension. I DO know that they have a different part number for the Z51, so I don't think they will work. You can go to Baer's website and send them an email to ask. They are pretty good about getting back to you. Here is the website:
www.baer.com
To Cross drilled rotors
