TR Cheatr ls2 vs the TR Blower cams
Old May 6, 2007 | 10:57 PM
knkali's Avatar
knkali
Default TR Cheatr ls2 vs the TR Blower cams
Wouldnt the Blower cam acutually be a good cam even if you dont use it with a blower instead of the Cheatr? The specs are similar to the Cheatr and it looks like the intake specs would help with low end (DCR) and the lift a bit easier on the springs.
Thoughts?
Old May 7, 2007 | 10:40 AM
MR Z's Avatar
0MR Z
Former Vendor
Both cams are basically identical, but Goeff may have a couple of degrees difference ground into the cam. Also on the exhaust side it looks like he did a custom lobe design. probably to accomplish something different with each cam. I have spoken with Geoff severeal times and he always told me the cheatr cam would be excellent if I decided to supercharge my old ls7. Also soke to hime about the LS2 cheatr that on the site just yesterday. He was pumped up because that cam picked up 50hp on the dyno. Still drives and idles like stock. I say pick up the phone and give Geoff a call. He will be happy to answer ?'s about it.
Old May 7, 2007 | 01:01 PM
knkali's Avatar
knkali
I called and left a message
Old May 7, 2007 | 08:23 PM
Cory@LS2PortWorks's Avatar
Cory@LS2PortWorks
St. Jude Donor '09
The cheaTR only lost about 1/2 psi of boost on my old supercharged H2 combo. Granted... different application... but if it only lost 1/2 psi on that set up I would expect similar results on yours. The gain was very obvious over stock... even on a 6800 lb truck.
To TR Cheatr ls2 vs the TR Blower cams
