Rear end leaking?
Old May 8, 2007 | 08:27 AM
valdeztke's Avatar
valdeztke
Default Rear end leaking?
Well I searched and searched "rear ends" and all I could come up with was Spin yapping about gears and Cartek's new special price on gear installs
I was under the car just the other day and noticed that rear end fluid appeared to be accumulating and almost puddling along the diff case. Was there a TSB on the 2005 rears or could this be something else altogether?
I do hope GM has to replace this. Maybe I could sneak them a 4:10 setup
Let me know what you guys think! PS – How can I check the level of fluid? Just pull the plug and check?
Old May 8, 2007 | 08:45 AM
johnodrake's Avatar
johnodrake
Moderator
There are several places that the Diff could leak, but the likely place is where the diff mates to the trans. There is a large O ring seal. If this is leaking, dealer just replaces the O ring.
Old May 8, 2007 | 08:54 AM
valdeztke's Avatar
valdeztke
Who would you recommend? I don't really prefer to go to Koons. I've had some bad expierences there.
Old May 8, 2007 | 09:03 AM
johnodrake's Avatar
johnodrake
Moderator
I have used Sterling Chevrolet but never for mechanical that deep. Forum Member Sven has used Koons in Tyson and they are the NVCC sponsor.
Old May 8, 2007 | 09:14 AM
valdeztke's Avatar
valdeztke
The last time I brought a car in for warranty work I had to wait 2 hrs for a shuttle to take me back to the metro. They offer no complimentary vehicle while your car is being repaired. I purchased my last Corvette from Koons and that was a mess all in itself. Took 5 hours - 4 of which I sat in a chair fuming at the moron processing my paperwork....
Well I should probably get some fluid in it if I'm doing the twisties this weekend!
Old May 8, 2007 | 09:23 AM
johnodrake's Avatar
johnodrake
Moderator
Are you going on the Skyline Drive Ride on Saturday?
Note the fill hole in the pic....
Old May 8, 2007 | 09:30 AM
valdeztke's Avatar
valdeztke
I'll check the pics when I get home. I'm on a DOD server that doesnt like image sites.
I'll fill it up to the tip top and hope she holds up!
Old May 8, 2007 | 11:15 PM
haljensen's Avatar
haljensen
My '05 purchased 2-05 leaked at the gasket on the rear cover. It took two tries for the Dealer to fix it. The first they replaced the gasket (and forgot the friction modifier), the second time they replaced the warped cover, the friction modifier and another gasket.
Old May 9, 2007 | 06:01 AM
valdeztke's Avatar
valdeztke
thanks
Old May 30, 2007 | 06:35 PM
valdeztke's Avatar
valdeztke
thanks
No luck - anyone want to recommend someone in this area?
Thanks!
Old May 30, 2007 | 10:14 PM
AintQik's Avatar
AintQik
Dry it and check the housing for cracks. They are prone to do this and it will leak as described. If its cracked I would not do any twisties, if it lets go completely it could take the tranny with it. Ask me how I know.
Old May 30, 2007 | 11:02 PM
valdeztke's Avatar
valdeztke
Think this is something they would cover under warranty?
Old May 30, 2007 | 11:55 PM
runutzzzzz's Avatar
runutzzzzz
Thanks!
Your rear end is leaking huh........... Ohh on your car...
How bout Pohanka!!! Travis, the service writer is a great guy
They even offer loaners
Old May 31, 2007 | 07:10 AM
valdeztke's Avatar
valdeztke
Where is Pohanka?
Old May 31, 2007 | 08:47 AM
runutzzzzz's Avatar
runutzzzzz
Where is Pohanka?
R U Serious?!?!?! Chantilly! RT 50 and 28
Later
Old May 31, 2007 | 09:01 AM
AintQik's Avatar
AintQik
Oh yeah they should cover it. Its common and if you don't have any warranty breaking mods you should be good to go. Just check it before you go out. The carnage is not good.
Old May 31, 2007 | 09:12 AM
valdeztke's Avatar
valdeztke
Taking the car to Travis in the AM thanks Rob!
I wish they would sneak in a 4:10 rear while it was apart.
To Rear end leaking?
Old May 31, 2007 | 12:12 PM
runutzzzzz's Avatar
runutzzzzz
He's a great guy and his techs are great also! Tell him I said hi!
4.10 not if you want to go FI
Old May 31, 2007 | 02:01 PM
VET4LES's Avatar
VET4LES
I thought mine was leaking and it turned out it was coming out the vent. It's on the top left of the above picture. I read that a large percentage of suspected leaks are just the vent. Mine was after a long trip in hot weather at 75-80 mph. I cleaned it off and in the following year have no additional problems.
Old May 31, 2007 | 02:28 PM
valdeztke's Avatar
valdeztke
Did you have to replace the lost fluid or change fluid?
I'm also noticing a bit of a smell after I installed the headers - I'm hoping it isn't my clutch line rubbing and ready to catch fire
smells like burnt valves - like a dry burn. lean at WOT?
