maggie and headers
Old May 9, 2007 | 09:06 PM
knkali's Avatar
knkali
Default maggie and headers
just ordered a maggie and wondering should I leave the headers on?
I am reading that headers cause boost loss--true?
Old May 9, 2007 | 09:25 PM
crabman's Avatar
crabman
Yep, you lose a little boost. Most folks with headers step down on pullies to get it back.
Old May 9, 2007 | 10:32 PM
Gene Gorman's Avatar
Gene Gorman
Yes,more air in more air out. Swap out for a smaller pulley to make up for the loss in boost.
Old May 10, 2007 | 12:34 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
,TOTALLY!!
Old May 10, 2007 | 06:00 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Old May 10, 2007 | 08:14 AM
SickRick's Avatar
SickRick
Not "boost loss" in the same sense as turbo's (which come after the headers), which occurs because of the velocity loss of the bigger inlet pipe.
I actually think you wouldn't lost much with a maggie and stock heads, as the boost loss really occurs on the intake/cylinder. With AFR 255/70cc heads + cam, and a stock maggie setup - my expected boost of 7PSI ended up being 4PSI. We all kinda slapped our heads and went "DUH" (even though we informed maggie of the setup and asked them to pulley accordingly). Smaller front pulley's didn't do the trick, so it had to go out to Cali for a rear pulley swap. When I upgraded to the 122 case - we made SURE they pulley'd the rear so I could max it out @ 14lbs with a 3.2 - currently running 12lbs with a 3.3 (and a STOCK BOTTOM END).
So, KEEP your headers - smaller exhaust creates the flow bottleneck in clearing the cylinders that will kill off some power. An engine is an air pump - the more air you can get through it - the more power you can make. You MUST be able to effectively "exhaust" the additional air you're forcing in with a blower.
Another note: BEWARE THE CLOGGED CAT. After about 4K mi on boost with the (supposed) high flow cats that came with the SuperMaxx headers, one clogged solid, the other was on the way (clue, ran like a$$ and boost was up to 16lbs - another demonstration of the facts stated above - I wasn't getting MORE boost - I was impeding the clearance of the cylinders and getting a BACKUP). I ended up gutting the cats. Car got like 25% LOUDER, but I don't have to worry about killing the cat anymore...
Rick
Old May 10, 2007 | 09:10 AM
knkali's Avatar
knkali
thanks for the post RicK
Old May 10, 2007 | 02:56 PM
snappy28's Avatar
snappy28
Cruise-In VIII Veteran
How does the cat get clogged?
Old May 10, 2007 | 03:53 PM
knkali's Avatar
knkali
i think it melts and caves in
Old May 10, 2007 | 10:51 PM
HITMAN99's Avatar
HITMAN99
With headers, boost "loss" is a good thing, means that the A/F isn't getting backed up in the plenum.
You will get a similar "loss" in boost if you add ported heads.
Old May 10, 2007 | 11:33 PM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
Knkali, High boost is not always an indication of more power achieved, it's usually an indication of ristricted and poor airflow. I used to own a 93 Mustang cobra procharged and intercooled on a built 302 motor. At full throttle with 1 3/4 super comp headers, catless set up and 2 1/2 cat back dynomax tips, the boost gauge showed 17lbs of boost.
I swaped the motor and went with a full race 331 stroker motor, fully ported canfield heads, solid roller cam, and same exhaust and blower pulley. Boost went down to 11 psi due to efficiency, and the motor generated 105Hp and 80lbs of torque over the old set up. Yes boost was lowered, but due to efficiency of the new set up, hp and torque sky rocketed. HEADERS are a must with a supercharged application.
Old May 10, 2007 | 11:36 PM
knkali's Avatar
knkali
Feel'n good guys --thanks for the info. Looks like the AR's are staying on. Now looking for the hood at a good price.
To maggie and headers
