Next ?...which head gasket
The felpro is like a composite of some sort. It seals really well, but I wouldn't use it if I was spraying nitrous or anything. That is where the cometic is different in that it is a MLS(multi layered seal) gasket. Basically very simlar to the stock gasket. I've used the cometic .036 and .051 thickness in the past and had no issues. Just make sure it's tq'd down properly because if it isn't it will not be as forgiving as the flelpro.
Is this on a stock LS2 build? I know AFR likes that Felpro 1040 as well because it has better quench than the stock gasket and is thick enough to where you really can't go wrong as far as quench goes.
Hope the info helps.
Dougie
