LS3 What is anyone thinking for stroking
Old May 11, 2007 | 02:46 PM
johnrigby's Avatar
johnrigby
8th Gear
Default LS3 What is anyone thinking for stroking
Now that the LS3 is fact on the 2008 with a 6.2L displacement, what is the thought process that any has pondered about stroking it. I believe with the bore size of ~4.065 with a 4.1 stroke it is equal to a 7.0 L motor. Is there a physical limitation on the stoke length on this new motor.
OBTW Does anyone know if the Z06 7.0 can be stroked too.
Old May 11, 2007 | 03:50 PM
andreas g.'s Avatar
andreas g.
Default First kid on the block with one
I've got a stroked LS3 ( L92 ) 4.065 boreX 4.1 stroke = 427 ci. It's in my 05 C6 6sp Z51. It also has CNC ported L92 heads Flowing 360 cfm in/270 cfm ex. Better than stock ls7 heads. The cam is a mild street cam,232/234/595/598/112LSA's with a speed density tune, it ildes great.It's a daily driver,it had to. This is a road car not a drag car. Even with a mild cam it dynoed 525rwhp/500rwtq. All the internals are forged. egale crank, scat rods, diamond pistons. The heads have ARP studs. It's a stout bottom end. It should live a long life. As time goes by the LS2 stroker will fade and these L92's will be the standard. Also I wouldn't be surprised if the standard motor for the C7 2010 is the LS7 505 hp, and the 700hp supercharged motor being in the high end car as the Z06 is today. Anyway love the motor, great power, very happy with it.
andreas g
Old May 11, 2007 | 04:58 PM
johnrigby's Avatar
johnrigby
8th Gear
Default So my idea isn't based on fantasy
Sounds like a great combo you got for the street, I may have to clone it some day
Old May 13, 2007 | 03:52 AM
TTRotary's Avatar
TTRotary
Umm, they're already out there, readily available. 418 ci strokers, look it up. $4,700 or so for a bare block. Remember, this engine has been available in trucks / Escalade for a year now.
Old May 13, 2007 | 08:59 AM
valdeztke's Avatar
valdeztke
Its the LSX block right?
Old May 13, 2007 | 01:47 PM
aTX427
Guest
Posts: n/a
I think it is just called the L92 block. The LSX is the new iron GMPP block that supports up to 481ci.
Old May 15, 2007 | 01:17 PM
johnrigby's Avatar
johnrigby
8th Gear
Default Second part of question not answered
So can the 7.0L be stroked?
or is it at it's physical limitations now
Old May 15, 2007 | 05:33 PM
andreas g.'s Avatar
andreas g.
yes the LS7 can be stroked. 4.1 would be the max. SDPC has them. Short block is $6,289. 440 inches. Anymore than 4.1 inches and the piston would be comming out of the bottom of the cylinder to far. You would need a taller deck for more stroke.
Old May 16, 2007 | 08:32 AM
johnrigby's Avatar
johnrigby
8th Gear
Default Thanks Again
after reviewing the specs I thought so but its always nice to get concurrence (sp)
Old May 16, 2007 | 04:23 PM
johnrigby's Avatar
johnrigby
8th Gear
Default Need the URL for SDPC for the short block
Searched site but no luck finding it
To LS3 What is anyone thinking for stroking
