Fitment issues with Kooks header...
Old May 14, 2007 | 10:58 PM
Ultimate CC's Avatar
Ultimate CC
Default Fitment issues with Kooks header...
Yesterday I installed the Kooks 1 7/8 header and offroad 3in xpipe and they sound great with the stock catback and feel even better...only two issues I am having, one was that GM somehow had the passanger side 02 wire zip tied behind the bracket on the firewall and it took forever to get it out...delayed me some but I got it and then I am also having issues with the exhaust rubbing in two places in particular...one is the drivers side header is hitting the bellhousing and then its also hitting in the back on the drivers side where there is an aluminum heat shield...I have tried to adjust it several times and it still after some driving goes back to hitting in those same areas...am I the only one with this issue?
Old May 14, 2007 | 11:28 PM
silverlx's Avatar
silverlx
I was hoping to install mine this past Sat, however my midpipes weren't opened up enough to slide onto the X-pipe. I'm still waiting to hear from Kooks and will call again Tues.
Old May 14, 2007 | 11:31 PM
Ultimate CC
yea i have been really disappointed with the fitment of these...for the money i would expect better...
Old May 15, 2007 | 12:30 AM
EBCBME's Avatar
EBCBME
Wow....I was going to order these for my '07 this week.....had it down to Kooks or LG's. Had Corsa sports installed at Corsa facility and Tech said Kooks and LG pretty much equals. Anybody else with fit issues....Kooks or Lg's? THANKS
Old May 15, 2007 | 12:31 AM
achilds's Avatar
achilds
When I was researching headers, I read about fitment issues and other problems with Kooks. I went with a different manufacturer for this reason and they bolted right up with no real problems. I understand that once you get the fitment issues worked out the product is a good one. Good luck, I am sure you will be satisfied once the bugs are worked out.
Old May 15, 2007 | 02:33 AM
crabman's Avatar
crabman
For what its worth people have reported fitment issues with LGs, kooks, Dynotech, and ARH. I went ARH and there is a spot on the starboard side where the header comes up close to the seam at the forward end of the tunnel. Mine barely cleared this and I trimmed it a little so I wouldnt have to worry about it rubbing there. At least they had a warning in the instructions saying that it would be very close in that spot and trimming might be required to clear.
Old May 15, 2007 | 02:52 AM
cbrf4i1's Avatar
cbrf4i1
are you not having fitment issue on the passager side tranny oil cooling lines? on vidal1313 car the tranny oil lines end up been bend a little to get clearnence, but there was no driver side issue.
Old May 15, 2007 | 03:37 AM
311badger's Avatar
311badger
I installed 1 3/4" kooks with high flo cats and Corsa sport on my 07' C6 A6 Z51. It's been 20 years since I turned a wrench on a car, but after reading the many posts I decided to take this on. The hardest part was jacking the car up high enough, with a floor jack and stands, to get the clearence (19"). It took about 8 hours for me to install the kooks headers, high flow cats, Corsa sport exhaust and Vararam Snake Charmer. Everything went as easy as advertised and without a second pair of hands. I'm extreamly pleased with the results. Last week I had a ZO6 cam installed with a street HP Tune, HOLLY CR@#!!. I'm schedueling a dyno tune with O2 sencors for next week to squeez the last few HP out and will post the results.
Old May 15, 2007 | 06:44 AM
Joe Lynch's Avatar
Joe Lynch
St. Jude Donor '09-'11
1-3/4 LG Pro here no problems at all. Fit was perfect. No experience myself with Kooks. Friends locally have them, no problems either. 1-7/8 gotta be a tighter fit than the smaller ones however.
You can dent the tube slightly if you are worried about it, won't hurt a thing other than the looks. You guys haven't lived until you have put headers on a DOHC Mustang. Torch and hammer required.
Joe
Old May 15, 2007 | 06:56 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
my kooks went on without a problem, no rubbing and plenty of clearance. i had them cleaned and coated before the install.
'05, mn6, f55, 1 3/4" kooks lt headers.
Old May 15, 2007 | 10:45 AM
mblock66's Avatar
mblock66
What is the benefit of going with the 1 7/8 over the 1 3/4 kooks (or other headers)
Would seem to me that without some sort of Forced Induction that the larger headers would cause a loss of low end TQ. You may get it back in the upper RPM HP range but I doubt it. Do people put on the 1 7/8 b/c they are going to super charge or turbo the application and the larger pipe is needed to get the exhaust out?
Old May 15, 2007 | 10:59 AM
Ultimate CC
yea no i bent those out of the way and there is no issue on the passanger side by the header...
Old May 15, 2007 | 11:03 AM
Ultimate CC
well after doing lots of research I decided to try and go for a little more out of the car with the 1 7/8th but now maybe this is why they don't fit so well...its not terrible but I don't like having a rattle on a 50+k car...
Old May 15, 2007 | 11:19 AM
chemten's Avatar
chemten
strange you are having fitment problems. mine fit just fine with the offroad pipe and corsa rear.
Old May 15, 2007 | 11:26 AM
Ultimate CC
yea I will keep adjusting it but its still going to be close no matter what I do...the header by the bellhousing has no adjustment...maybe a hammer
Old May 15, 2007 | 12:28 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I installed the 1 3/4" Kooks at home in 4 hours. Everything fit perfect with no rubbing problems.
Old May 16, 2007 | 11:13 AM
KOOKS Headers's Avatar
KOOKS Headers
We make make everthing in house by hand. Sometime's there can be a slight variation in production. We stand behind our product 100%. That is why we have been in business for over 45 years and thats not combined. Thats also why we have a rep for being #1 in custumer service. So please give me a call so we can take care of this for you ASAP. 1 866 586 kook ext 308.
To Fitment issues with Kooks header...
Old May 16, 2007 | 11:25 AM
CRZFINN's Avatar
CRZFINN
same here. I'm very pleased about the fit & finish on the Kook's product.
Old May 16, 2007 | 11:30 AM
stinky's Avatar
stinky
Old May 16, 2007 | 11:13 PM
kermooni's Avatar
kermooni
I have Kooks 1 7/8" with Hi-flow cat X pipe and stock mufflers. No fitment no codes and lots of power with the addition of LPE CAI and a tune (378 HP, 380 TQ)
I do have drone around 1500 - 1900 RPM which Corsa will cure later this summer.
