L92/L76 Results
BEFORE(mild cam,FAST intake,LG headers,tune) 421.2RWHP 392.3RWTQ
AFTER(L92/L76,same as above but no FAST) 447.1RWHP 404.4RWTQ
There is a 30RWHP increase and a 25RWTQ increase at 6250RPM
I'll try to post the dyno soon. From 4500RPM on , the new set up is a monster and did a little better in the low end than my previous set up. Best of all, IMO, is that the car idles and sounds STOCK.I didn't opt for a pully as I wasn't sure that the cam was going to swapped, and it may be some time in the future,when I'll get a pully as well, but for now , I hit my target of 450RWHP
BTW, uncorrected(STD dyno read out) says the car has 454RWHP and 414RWTQ, but I listed the SAE corrected, as most go by this. By far, this is the strongest the car has ever pulled at HWY speeds, should be fun at the track.The heads were milled and the car is at 10.25:1 compression, a different cam may help that too.Any comments appreciated.BTW, BC Bob, I reccommend itBEFORE(mild cam,FAST intake,LG headers,tune) 421.2RWHP 392.3RWTQ
BTW, uncorrected(STD dyno read out) says the car has 454RWHP and 414RWTQ, but I listed the SAE corrected, as most go by this. By far, this is the strongest the car has ever pulled at HWY speeds, should be fun at the track.The heads were milled and the car is at 10.25:1 compression, a different cam may help that too.Any comments appreciated.BTW, BC Bob, I reccommend itYou should have had the shop mill the heads .030 to get back to ~ stock 10.9:1 compression, but not bad considering your compression dropped so much.
Always helpful
Please remember, the RWHP difference is from my last dyn run with the FAST installed. Before the FAST, I had 406.5, so if you take that into account, the L92/L76 took me from 406.5 to 447.1RWHP, thats a gain of 41RWHP for the $$. I did not get caught up in the GOTTA HAVE IT, though. Thats a little unneccesary to say that. I simply saw that there was a combo being produced that fit what I was looking for , but it came too late because I had already done the FAST. BTW, I also re couped $$$ from both builds by selling the old cam, intake and FAST. The $$ to HP result is hard to beat when all factors are accounted for.
"GM uses the their 70.2cc L92 head and L92 truck manifold on the 6.0L block in 2007 on the Vortec MAX option (same block pistons rods and crank used in 2006 LQ4 option) and added another 20+hp and torque to the factory rating compared to 2006."
I have not validated the accuracy, but I believe it's true.
